[Tutorial] Samba Configuration
Install
sudo su
apt update
apt install samba
Server name
- any os file browsers:
hostnamectl set-hostname [name]
- only Windows(NetBIOS) file browsers:
netbios namein/etc/samba/smb.conf
/etc/samba/smb.conf
[global]
# netbios name = [name]
workgroup = WORKGROUP
server string = Samba %v on %L
wins support = yes
domain master = yes
preferred master = yes
local master = yes
os level = 255
dns proxy = no
log level = 0
socket options = IPTOS_LOWDELAY SO_RCVBUF=131072 SO_SNDBUF=131072
min receivefile size = 2048
use sendfile = yes
aio read size = 2048
aio write size = 2048
write cache size = 1024000
read raw = yes
write raw = yes
getwd cache = yes
oplocks = yes
max xmit = 32768
dead time = 15
large readwrite = yes
guest ok = yes
map to guest = bad user
encrypt passwords = yes
load printers = no
printing = bsd
printcap name = /dev/null
disable spoolss = yes
[readwrite]
comment = browseable, read, write, guess ok, no password
path = /media/hdd/readwrite
read only = no
[read]
comment = browseable, read only, guess ok, no password
[root]
comment = hidden, read, write, root with password only, from [IP1] [IP2] only
path = /media/root
browseable = no
read only = no
guest ok = no
valid users = root
# host allow = [IP1] [IP2]
Restart
systemctl restart smbd nmbd
Test conf parameters
testparm
Add user + password
adduser [user] # create new system user if not exist
smbpasswd -a [user]
