TV dongles drivers
Hello
Is it possible to implement the same drivers than in vero 1 for the TV dongles ?
Here you can find my two dongles who’s works on the Vero1.
Thank you
Hey ho !
Is anybody here ?
Everybody is here but your original message was not really clear. Driver base for Vero1 and Vero2 should be identical.
Provide the lsusb output as well as the dmesg output from Vero1 and Vero2 to enable the team to identify what’s going on.
Hi – I think we received some requests for this before.
Can you plug both sticks in (let me know which is which) and type dmesg
http://paste.osmc.io/efotofexen.coffee
and here the lsusb
osmc@osmc2:~$ lsusb
Bus 001 Device 004: ID 15f4:0131 HanfTek
Bus 001 Device 003: ID 0572:c688 Conexant Systems (Rockwell), Inc.
Bus 001 Device 002: ID 05e3:0608 Genesys Logic, Inc. USB-2.0 4-Port HUB
Bus 002 Device 002: ID 1997:2433
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Thank you
Hello
Do you have work on this issue ?
Can you provide the lsusb for both of the dongles you want us to add support for?
the lsusb fot DVB T210
and the second
Bus 001 Device 005: ID 15f4:0131 HanfTek
Thanks. We have backported media drivers for Vero 4K, but it may be causing an issue with remote control support. When this is stable, I will look at doing the same for Vero 2.
