Hi All,
Hoping someone can help me with an issue I’m having with pixelated tv-show episode thumbnail pictures (see below). This only seems to affect tv shows where there isn’t official artwork available for each episode and it randomly displays a scene from that episode. It also does’t affect all episodes, though it seems random.
Screenshot displays fine
Format : Matroska
Format version : Version 4 / Version 2
File size : 6.32 GiB
Duration : 23 min 42 s
Overall bit rate : 38.2 Mb/s
Encoded date : UTC 2010-02-22 21:41:31
Writing application : mkvmerge v5.9.0 (‘On The Loose’) built on Dec 9 2012 15:37:01
Writing library : libebml v1.3.0 + libmatroska v1.4.0
Video
Format : AVC
Format profile : High@L4.1
Format settings : CABAC / 2 Ref Frames
Format settings, CABAC : Yes
Format settings, ReFrames : 2 frames
Muxing mode : Container profile=@0.0
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Variable
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Default : No
Forced : No
Screenshot pixalated (see picture below)
Format : Matroska
File size : 5.67 GiB
Duration : 23 min 43 s
Overall bit rate : 34.2 Mb/s
Video
Format : AVC
Color space : YUV
Bit depth : 8 bits
Default : No
Forced : No
Thanks in advance!
