Vero 4K+ with NFS mount of a network share (/mnt/HomeShare).
Within HomeShare there’s two key folders, TV and Movies. I have added these sources, declaring one as Movies the other as TV Shows. This setup has worked for a very long time but I have an issue now I just don’t understand. TV shows folder structure is typically like this -
/mnt/HomeShare/TV/Show Name/Season Folders
I recently put some new TV shows onto the NAS
/mnt/HomeShare/TV/Show X/Season1/Episode 1.mkv
/mnt/HomeShare/TV/Show X/Season1/Episode 2.mkv
/mnt/HomeShare/TV/Show X/Season1/Episode 3.mkv
/mnt/HomeShare/TV/Show X/Season2/Episode 1.mkv
/mnt/HomeShare/TV/Show X/Season2/Episode 2.mkv
/mnt/HomeShare/TV/Show X/Season2/Episode 3.mkv
From the top level menu, the show is found but only shows S01E01, not the remain episodes. I assumed file permissions have messed up, but they’re all accessible by osmc:osmc user.
If I navigate through files and tv and then select the show all season folders are shown, and I can play back the files.
Its like a disconnect between the top level menu, and the files. Any ideas?
