I’ve been using Kodi (OpenELEC) for a while now on my Raspberry Pi and it has the nice option of putting your TV in standby mode using CEC when the screensaver (dim) start.
Recently I got curious about OSMC and decided to give it a try. So far I really like the interface, however I have not yet found the option to enable the mentioned functionality. Can anyone point me in the right direction?
You probably want the Settings menu:
Settings|System|Input and then look at Peripherals where the CEC configuration is. That gets the option as to what to do when ScreenSaver is activated
Derek
That is correct. I was too focussed on the “Screensaver” and “Power” settings, that I forgot to look under “Peripherals”
Thanks for the info!
