Hello, I’m new to OSMC, i came from libreelec there i installed the tvheadend server with oscam. That connected with eachother but there was a driver problem. In OSMC the dvb-s tuner works correctly but i see no option in tvheadend to connect to an oscam server (option CAs). Is there a way to get that option?
EDIT: I’ve found a solution, i had to change the “Persistent View Level” to “Expert” in Config -> General -> Base & reload
