Hi. Every so often when I turn on a channel, the stream plays but without audio. Changing to a different channel then back again often fixes it. Sometimes I need to cycle though a few channels/ change mux to fix it. Very occasionally I only get audio and no video, but this is rare. I’m seeing some continuity counter errors (H264/aac) in tvheadend logs. I believe this was an issue before updating to kodi 19, and that the issue may be limited to hd channels, but can’t be sure.
My setup seems pretty basic…two osmc dvb tuners plugged into powered usb hub. Tuners and playback on same machine. I can provide logs next time it happens but not sure how to capture tvheadend logs. Thanks.
