TVHeadend crash
So odd time after the system has been idle, I goto play a recording and I get this
2024-09-22 12:52:04.685 T:6168     info <general>: CActiveAESink::OpenSink - initialize sink
2024-09-22 12:52:04.686 T:6168     info <general>: CAESinkALSA::Initialize - Requested layout FL, FR
2024-09-22 12:52:04.687 T:6168     info <general>: CAESinkALSA::Initialize - set digital codec 0
2024-09-22 12:52:04.688 T:6168     info <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2024-09-22 12:52:04.709 T:6168     info <general>: CAESinkALSA::Initialize - Opened device "default"
2024-09-22 12:52:04.709 T:6168     info <general>: CAESinkALSA::InitializeHW - Your hardware does not support AE_FMT_FLOAT, trying other formats
2024-09-22 12:52:04.710 T:6168     info <general>: CAESinkALSA::InitializeHW - Using data format AE_FMT_S24NE4
2024-09-22 12:52:04.712 T:6168     info <general>: CAESinkALSA::Initialize - speaker layout 0
2024-09-22 12:52:04.734 T:6149  warning <general>: CreateLoader - unsupported protocol(sources) in sources://music.tbn
2024-09-22 12:52:24.346 T:6149     info <general>: Loading skin file: MyPVRRecordings.xml, load type: KEEP_IN_MEMORY
2024-09-22 12:52:33.790 T:6149     info <general>: VideoPlayer::OpenFile: pvr://recordings/tv/active/Robson Green's Weekend Escapes/Robson%20Green%27s%20Weekend%20Escapes%208%2f15.%20Robson%20meets%20Paralympian%20Tanni%20Grey-Thompson.%20They%20cycle%20around%20the%20shores%20of%20Northumberland%27s%20Kielder%20Water%20before%20braving%20a%20zip%20wire%20ride%20and%20a%20canoe%20trip%20on%20the%20reservoir.%20Also%20in%20HD.%20%5bS%2cAD%5d, TV%20(BBC%20ONE%20Yks%20HD), 20240919_133131, 1424630342.pvr
2024-09-22 12:52:33.805 T:11657    info <general>: Creating InputStream
2024-09-22 12:52:33.820 T:11657    info <general>: Creating Demuxer
2024-09-22 12:52:34.913 T:11657    info <general>: Opening stream: 0 source: 256
2024-09-22 12:52:34.914 T:11657    info <general>: Creating video codec with codec id: 27
2024-09-22 12:52:34.915 T:11657    info <general>: CDVDVideoCodecAmlogic: using Amlogic decoder H.264/MVC
2024-09-22 12:52:34.921 T:11657    info <general>: DVDVideoCodecAmlogic: Opened Amlogic Codec
2024-09-22 12:52:34.921 T:11657    info <general>: Creating video thread
2024-09-22 12:52:34.922 T:11657    info <general>: [WHITELIST] Searching the whitelist for: width: 1920, height: 1080, fps: 50.000, 3D: false, 3d mode flags: 0x0
2024-09-22 12:52:34.927 T:11657    info <general>: Display resolution ADJUST : 1920x1080 @ 50.00 - Full Screen (27) (weight: 0.000)
2024-09-22 12:52:34.927 T:11658    info <general>: running thread: video_thread
2024-09-22 12:52:34.961 T:6149     info <general>: VideoPlayer: OnLostDisplay received
2024-09-22 12:52:34.961 T:6149  warning <general>: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
2024-09-22 12:52:35.257 T:6149     info <general>: VideoPlayer: OnResetDisplay received
2024-09-22 12:52:35.257 T:6149  warning <general>: CDVDMessageQueue(audio)::Put MSGQ_NOT_INITIALIZED
2024-09-22 12:52:35.268 T:6149     info <general>: Skipped 1 duplicate messages..
2024-09-22 12:52:35.268 T:6149     info <general>: GLES: Maximum texture width: 4096
2024-09-22 12:52:35.287 T:11657    info <general>: Opening stream: 1 source: 256
2024-09-22 12:52:35.287 T:11657    info <general>: Finding audio codec for: 86065
2024-09-22 12:52:35.289 T:11657    info <general>: CDVDAudioCodecFFmpeg::Open() Successful opened audio decoder aac_latm
2024-09-22 12:52:35.289 T:11657    info <general>: OpenStream: Allowing max Out-Of-Sync Value of 50 ms
2024-09-22 12:52:35.289 T:11657    info <general>: Creating audio thread
2024-09-22 12:52:35.290 T:11657    info <general>: Opening stream: 3 source: 256
2024-09-22 12:52:35.291 T:11660    info <general>: running thread: CVideoPlayerAudio::Process()
2024-09-22 12:52:35.326 T:11657    info <general>: CDVDDemuxFFmpeg::Read() stream change
2024-09-22 12:52:35.453 T:11657    info <general>: Opening stream: 0 source: 256
2024-09-22 12:52:35.454 T:11657    info <general>: Creating video codec with codec id: 27
2024-09-22 12:52:35.454 T:11657   error <general>: CDVDVideoCodecAmlogic::Open - InstanceGuard locked
2024-09-22 12:52:35.454 T:11657    info <general>: CVideoPlayerVideo::OpenStream - could not open video codec
then unhappy face and restart, then the file will play
Impossible to tell without a full log. Can you always reproduce it with this recording?
no, unhappy face , osmc restarted media center, works first time
It seems its when the box has been idle for a while, then i get home and first time it does it
when I say first time though its not every day, might be once a week
I can add logging into config file. itll work fine all day etc , going between tvh, and other files
No need. We have checked this and it’s already been fixed, but hasn’t been released as a stable update yet.
I can give some update instructions if you’d like to try the changes now
yeah if you could please
Hopefully the issue is now addressed with the following commit:
  1. Login via the command line
  2. Run the following command to add the staging repository:
  3. Run the following commands to update: sudo apt-get update && sudo apt-get dist-upgrade && reboot
  4. Your system should have have received the update.
I also recommend you remove /etc/apt/sources.list.d/osmc-devel.list after updating.
This will deactivate the staging repository. You can do so with the following command:
sudo rm /etc/apt/sources.list.d/osmc-devel.list.
I’ve had the same problem, which I assumed was a power-supply issue until I spotted this thread. Kodi would crash about 10% of the time when starting to play a recording if the HDD was spun-down, with an error message in journalctl Undefined symbol audio_decode_stop in /usr/osmc/lib/libamcodec.so.
I’ve updated the system (Vero 4k+) from the osmc-devel repo and so far at least it seems to have resolved the issue.
Since this and sorting out other issues, I havent had a crash since
My TVHeadend records to a SSD on a NFS share, so duno where the issue was, but its defiently fixed
Indeed, this issue should be solved in today’s update.
