Amir
27 April 2016 06:17
1
I thought to play with TVHeadend yesterday. I have the following usb based sat receiver
http://www.hauppauge.co.uk/site/products/data_novahdusb2.html
I have installed The app from App store within OSMC, The web page is visible but under devices, i am unable to find it. Do you know if i need to add firmware/driver in OSMC or if the sat is supported at all.
thanks.
Amir
27 April 2016 06:27
3
EDIT: got it mixed up its for DVB-T varient… fzinken: you are right, its not supported yet…
I just investigated it further
on the following page
https://wiki.ubuntuusers.de/DVB-Karten/
i see the firmware with the following link,
http://www.linuxtv.org/downloads/firmware/dvb-usb-dibusb-6.0.0.8.fw
Would it be possible to use it, i can give it a try… but i dont know how the fw file useable.
regards,
Well Firmware is only the second step after first having the driver.
Post the URL of grab-logs -J
