Hard to say from this alone, can you reproduce, then upload some logs?
yeah, let me know how to run the logs and where to download them and i`ll sort them tomorrow
Agreed, but there was probably already a partition table there since most storage comes pre-formated with NTFS on HDDs and exFAT on flash storage.
OTOH, āmy X: driveā, as used by Windows, would really apply, for once instead of the more technically correct āMy X: partitionā.
BTW, Iām looking to move from 7MC in the next month for OTA recording just like the OP. Wrote a little script using wget and timeout to ārecordā channels using start-time and duration already. Scheduled using āatā. With HDHR devices, ārecordingā is exactly the same as downloading a file for a specific duration.
Have 6 HDHR network tuners (2 devices) which are extremely compatible with everything in North America. Unfortunately, the EPG data here is only for a few hours before showtime. To get anything longer requires $25/yr payments for schedule data. Tried to use TVHeadend a few years ago and found the configuration way, way, to complex. Think Iāll create my own batch scheduling tool based on a text file that gets read 3x a day. It will probably be much like a crontab, just with a duration, channel and program title added. Need to think about keyword-based recordings a little more.
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Hi Sam
https://paste.osmc.tv/duxucesaqi
I enabled the log, then shutdown, unplugged power from USB hub and vero4k, then put power back to both, the sony adapter works.
i then rebooted vero4k and the sony adapter wasnt there
then ive got the log file link
Okay, looks like a bug. Iāll try and reproduce over the weekend.
cheer sam,
solution for now is wifi plug sockets so i can turn power off to both then turn them back on lol
Iāll come up with a proper solution, donāt worry.
nice one,
Should the signal strength work?
I never get a issue with picture so dont believe its 0% lol
The 754mhz mux, i think is turned off on our transmitter, it does say they was starting changing something on it in 2020, but looking at the humax box on a different aerial that also doesnt fins the channels on that frequencey
The driver doesnāt pass the strength through currently. This can be safely ignored.
Hi Sam,
Did you have any luck finding a solution?
So far whilst its up and running it works great much better then WMC
I would say there are allot more options but some take some working out due to the naming, and some times when you set up profiles you need to stop/start server for them to show where you select them in drop down menus
what would you set the recording stream to be? pass , mkv etcā¦
just had a strange thing where i recorded a 2 hour program, skipped it to half way, but when i fast fwd it it went into rewind but kodi x32 showd as ffwd but count went donw, then noticed it would fast fwd from 1hr00mins to 1hr15mins then go down after that untill it was at 0:00
Sorry for getting back to you so late about this.
This should be fixed in the 4.9 kernel which is still in testing phase but is getting more in shape each week.
I would record files as MKV where possible. This will make sure that seeking works properly.
Hi Sam,
its ok you replied on a PM, but you said to use TS, its been fine since.
The only odd issue i get is when i try to play a recording first time of a day, it shows the circle loading then stops, if i try again straight away the OSMC usually freezes and needs to be rebooted, but if i wait 10 secs then try the recording opens straight away. Guessing it has some thing to do with HD going to sleep
thanks
Carl
It could be. In the network section of the My OSMC add-on do you have āwait for networkā enabled?
yeah thats highlighted so is on
You might try settings>system>power saving>maximum wait time for network>(30 sec)
I donāt know if it will make a difference but itās probably worth a shot.
this was set to OFF, so isnt that like untill it responds?
You can also try something like
<videolibrary>
<playlisttimeout>60</playlisttimeout>
</videolibrary>
<musiclibrary>
</musiclibrary>
in your advancedsettings.xml.
(see https://kodi.wiki/view/Advancedsettings.xml#playlisttimeout) ⦠but no guarantee this helps with your issue since itās only valid for items in the video and music libraries.
Off is the default setting. TBH iām not sure which setting affects which particular function but the general idea being to increase the time Kodi waits for the file to become available. If you have a delay from a network drive slow to spin up or similar then your not going to get rid of that in Kodi but you may be able to increase the timeout so it plays the first time you tell it to.
I tried setting it to 30, but tbh it circles for 10 secs then stops, it might be because its loading from TVheadend and its not a actual KODI library?
