yep, that’s why I first wanted to delete my post
yeah, just found in there theres also timeouts so set them to 30, will see if that solves it tomorrow
yes, the second one is promising
still did same, loading… for 10 secs then stops
I could intermittently reproduce your issue with my connected 3 TB USB hdd, placing the TVH recording folder there and forcing the device (/dev/sda) to standby invoking sudo hdparm -y /dev/sda
But the configuration of “Tvheadend HTSP Client” like shown in the screenshot, fixed it for me:
Especially the second value (default=5) seems to be responsible for the behaviour in my environment.
I changed both to 30 yesterday, but i didnt restart the client, as in disable / enable. Had it before where setting dont update once changed
Tried the standby command you used and then waited a min before playing a recording and that seemed to work, so i`ll try it tomorrow see if its fixed it
