Since the upgrade of kodi, on TV headend the picture at the top and bottom looks jumpy/flickery
If i record the program and play it on vero4k its the same, but if i play it on laptop it plays normally
https://photos.google.com/share/AF1QipNOSNBSCuuyLWYngbwlV8eze-OZyTR1QTumaCh69Lof5dn62-4-vxhNuhMDg9RMRw/photo/AF1QipPyImR6pBR12s_OoBwlTQ2YvuXq3kiKSUJsQ0uD?key=eGY0UkVISjQtejNRR1FJNW5RR201MGtiZUU5WkJR
Is there a setting to correct this?
I have the TS file but dont know where to upload it
Looks like a potential issue with deinterlacing.
It would be good to get debug logs first.
Cheers sam, see below, didnt know if it was some setting
https://paste.osmc.tv/fidirofani
Need full logs --those seem to only be APT logs.
unsure, i enable logging, reboot twice then run grab-logs -A, before i ran grab-logs -a if theres a difference?
but now it doesnt show me a link
Where can i upload the log file?
Try again – was doing some maintenance on the paste server.
Don’t think you had debug logging on, so:
- Was it an HD channel or SD?
- Does this occur on all channels?
logging was enabled, top left side shows all info frame rate, memory etc
It was on channel 30 - 4music - SD, tried 42 - SD thats same
HD channels look fine
Change Accelerate MPEG2: Always to HD and Up.
Cheers Sam, that worked
Just dont remember any settings been changed after upgrade
