Hello everybody,
As you will notice quickly: my English is really bad. I am totally dependent on google translate. but I hope that you understand me anyway.
I’m new here, have almost no Linux experience and try nevertheless, to help myself.
But now I’m stuck.
I’ve only tried tv headend manually install.
For this I advanced “/etc/apt/sources.list” with the entry “deb Index of /stable/ jessie main”, but then appear to the fetch of the packets and attempt to install with the error message in German:
W: bust when fetching http://apt.tvheadend.org/stable/dists/jessie/InRelease Expected entry »main / binary-armhf / Packages" could not be found (incorrect entry in sources.list or release file malformed file).
E: Some index files failed to download. They have been ignored or old used in their place.
First I vermutele an error when adding the sources.list (for example, an invalid character).
In the installation attempt of tvheadend server 4.05 on the App Store OSMC however the following error appears to me.
OSMC Update Error:
** Error installing:**
** Please report this on the OSMC forum.**
I think the day before yesterday I managed to install from the App Store.
Now I hope for your help.
Thanks in advance.
Andreas
If anyone is interested: My problem has a long history:
I’m trying to run to get tvheadend to receive in Germany via DVB-T2 broadcast HD channels. At first I used the OpenELEC Distribution. Thus ran tvheadend right away and I could even scan and HD channels for some manual configuration. But unfortunately you can these channels in the frontend not watch because the HD stream stops when Buffering 0% immediately. As I found out, this is a bug under Kodi 15.2. A stable distribution higher than version OpenELEC 6:03 with Kodi 15.2 is currently not to get.
sysinfos:
OSMC (Kodie 16.1 RC3)
Raspberry Pi Model B 3
DVB-T USB stick August DVB-T210 (Chipset: Geniatech T230)
