when i add my local playlist via the “url” eg. file:///home/osmc/playlisttestANSI.m3u
I get errors like
iptv: invalid error code 400 for ‘rtsp://10.0.0.33/?src=1&freq=12604&pol=h&msys=dvbs&sr=22000&pids=0%2C7290%2C1290%2C0%2C2290%2C1290%2C18%2C17%2C16’
clearly there seem to be troubles regarding the encoding as the %2C ascii code should be interpreted as commas.
I have already tried several of the listed content encodings in the advanced settings of the therefore created network without success.
Could this somehow origin from running it on OSMC?
you mean replacing %2C by commas?
either I got you wrong or the other way around
as in the file itself the links are correct:
rtsp://@10.0.0.33/?src=1&freq=12604&pol=h&msys=dvbs&sr=22000&pids=0,7290,1290,0,2290,1290,18,17,16
sry of course, it’s a SAT>IP Server - “Digital Devices Octopus NET V2 S2”
I tried to and it basically works well but it doesn’t support the CI cards/encryption.
Due to this I had to add the few encrypted channels manually to an IP network.
As they access the same source right now both networks interfere each other (epg grabbing blocks the other network or sometimes they don’t fast enough unsubscribe before the other one subscribes. An addition trouble is that I right now just can feed one tuner with a signal but can not deactivate it for the IP network, what also causes therefore “no signal” when the server tries to use the other tuner).
That’s why I want now completely switch to IP-Network as a source and limit it to one stream.
