TVHeadend keeps stopping
Hi.
I have OSMC running on a Pi4 and recently TVHeadend keeps stopping. Yesterday I did a clean installation and the problem is still happening.
Pease could I have some advice on how to work out what is wrong. I have looked for a logs but I can’t find any.
Thank you very much
Keith
What do you mean by ‘keeps stopping’?
You can upload logs via My OSMC.
Hi Sam
The server starts up and I can access it via the website and then later on I can no longer access it and I have to restart the server.
Here are the logs. I had rebooted and it failed almost right away.
https://paste.osmc.tv/zocunebena
Best regards
Keith
Hi Keith
Last messages we see are:
Jan 24 21:52:36 osmc-server tvheadend[998]: mpegts: too much queued table input data (over 2MB), discarding new
No idea what is causing that.
When did the issue start occurring?
Hi Sam
It started a couple of weeks ago when I was still on the June 2023 code I think it was.
I was going to try using a USB stick instead of an SD card but I kept hitting a problem with trying to set a fixed IP address for it. I had used the OSMC installer to create the boot SD to install it to the USB drive. When that didn’t work I tried a different version to load and I even tried loading it to the SD card but I kept getting Unhandled exception when I tried to apply the new IP address.
I then tried using the Pi Installer and that built the code on the SD card and I was able to then change the IP address.
Unfortunately I didn’t keep the logs for the failures using the OSMC installer
Best regards
Keith
