I just updated to the December release and TVHeadend doesn’t seem to be working. How do I tell what has happened to it?
Keith
Keith
Hi Sam
I uploaded the logs I think, I haven’t done this before, and it gave me the message
https://paste.osmc.tv/uvarilujum
Is that all you need
Cheers Keith
Keep seeing this in the logs:
11:13:26.002 T:1350562560 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - Command hello failed: No response received
11:13:26.002 T:1350562560 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - failed to send hello
11:13:31.003 T:1555821312 ERROR: AddOnLog: Tvheadend HTSP Client: pvr.hts - unable to connect to 192.168.1.28:9982
Doesn’t appear to be able to connect to the Tvheadend server.
Thanks Tom.
Further down it says that accesscontrol/1 is invalid
Apologies only quickly read the log, didn’t realise the server was on this pi aswell.
Seems similar issues has occurred before with an update:
https://discourse.osmc.tv/t/tvheadend-not-working/
I would check the tvheadend config file.
Thanks Tom.
As suggested by Tom I fixed it by deleting the file
/home/osmc/.hts/tvheadend/accesscontrol/1
and then rebooting.
For some reason I then had a problem connecting to SMB but another reboot after that fixed it
Thank you for your help Tom
All seems to be ok now
Keith
Glad to hear its sorted.
Tom.
