Good evening all, I’m hoping someone could help me out a little here.
I’m running the latest version of OSMC on a Raspberry Pi 2. It is using the OSMC app store version of Tvheadend server connected up to an HDHomerun Connect recording all the PVR content off to an Apple Time Capsule. All devices are on the same network segment and the time capsule is mounted up through CIFS on the OSMC device as an automount through fstab.
Everything has hung together fine up until recently. Now however if I reboot the OSMC device it will intermittently (around 50% of the time) not start the PVR client. When in this state it is still enabled as an addon and the TV section of Kodi settings shows it as still being enabled. While in this state, the tvheadend backend is actually still running and recording, plus I can still connect to it through http on port 9981. Disabling the PVR from the TV section of settings and enabling it again will bring things back to life or another reboot ‘may’ clear it.
It appears to be something to do with the client not always starting properly at boot time.
I have two sets of logs uploaded, first is of a reboot where the PVR client started fine:-
http://paste.osmc.io/fapewoquto
The second is of a reboot when the client failed to start properly:-
http://paste.osmc.io/tutehanura
The one obvious difference to me is that the not working boot has the following messages in the output.
htsp: 127.0.0.1 [ osmc | Kodi Media Center ]: Write error – Broken pipe
htsp: 127.0.0.1 [ osmc | Kodi Media Center ]: Disconnected
Any suggestions or other logs I should be looking at to help troubleshoot this further?
Regards.
