Hey All,
So I’ve spent this afternoon rebuilding a Pi3 with OSMC and TVHeadEnd. but when am home the home screen I get really bad tearing
Any ideas on how I can fix this? I’m guessing it might be a setting on the theme or in OSMC?
root@osmc:/home/osmc# cat /etc/os-release
PRETTY_NAME=“Open Source Media Center”
NAME=“OSMC”
VERSION=“March 2022”
VERSION_ID=“2022.03-1”
ID=osmc
ID_LIKE=debian
Hardware : BCM2835
Revision : a020d3
Model : Raspberry Pi 3 Model B Plus Rev 1.3
Simon
reproduce the issue
Logs are here
http://paste.kodi.tv/aseqefagug
have same issue on reboot as well. so can reproduce pretty easy
Unfortunately this isn’t a full log.
More details can be found here:
Thanks Tom.
Oh, how do I get it to capture a full log? Does it need to run for a certain length of time?
I followed the steps you posted
After the second reboot
Loaded tvheadend and started bbc one and the returned back to the home screen and then uploaded the logs
The link provided would have been to OSMC’s pastbin and this would have provided full logs.
Thanks Tom.
Does it work on another display?
I havent tried it. but it feels more OS related over the screen. as it’s like tearing through menus.
But I’ve got another screen I can try it on to confirm.
