When I go to My OSMC -> App Store -> TVHeadend Server -> Install -> Apply
I get a pop-up window labelled “OSMC Error” With the message: “Error installing: armv7-tvheadend-app-osmc (4.2.4-3) Please report this on the OSMC forum.”
So, in summary:
activate the logging
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
I didn’t know initially that the TVHeadend server was available in the App Store. So I tried using some online “tutorials” for installing it. This involved a lot of commands thru putty - and it didn’t work.
I suspected that those attempts (along with some leftover garbage from 3rd party addons I had tried a while back and quickly uninstalled) was fouling up the tvheadend install. So I wiped my SD card and did a fresh install. That did the trick and I was able to download the addon without problem.
But in a post to me on the official Kodi forum, you told me:
“You can then log in to the interface at http://IP-OF-KODI:9981 using osmc as both username and password.”
You did mean that I should use the browser (Firefox) on my laptop on the same network as my RPi to access that, right?
When I try, I get a “Server Not Found” error message.
As I said, I did a fresh install of OSMC. It cleared up the mess and allowed me to install the TVHeadend server wthout problem. I was also able to access the TVHeadend server setup without problem.
NOW, my problem is that when I am in the setup window, I cannot set the TVHeadend server to use the Hauppage usb tuner. From what I’m reading in the TVHeadend help, I need to install the drivers for the tuner before I can proceed with the setup.
OSMC itself isn’t giving me any problems now. So I don’t understand why you need any logs.
Please check the Raspberry Pi community on how to install and run an operating system on the Raspberry Pi.
All you need to do is connect the WinTV-HVR-955Q to a USB port on the Raspberry Pi.
You will also need the firmware which is not included with Raspbian Jessie. You can download the Conexant cx231xx USB firmware v4l-cx231xx-avcore-01.fw for the WinTV-HVR-955Q from Linuxtv.orgLinuxTV.org - Television with Linux You will need to copy the firmware file to /lib/firmware and reboot the system. That is all you need to load the TV tuner firmware and get the WinTV-HVR-955Q device detected.
So do I just download that file, put the SD card back in my laptop and copy over the file? My Hauppauge is a WinTV-dualHD (Model 955D).
You can only access the boot folder when putting the sd card in your laptop.
Download the program winscp on your laptop, install and run it and connect it to your raspberry pi ip. Input the username and password and connect. From there you can then drag and drop files from laptop over to the /lib/firmware folder
I downloaded the file ( v4l-cx231xx-avcore-01.fw) to my laptop. Established a connection over WinSCP. Went to drag and drop the file into lib/firmware as per the Hauppauge instructions. BUT THE FILE WAS ALREADY THERE!
If that’s the file for the tuner’s drivers, why isn’t it already setting up the drivers?
Strange. Although it needs more than just the firmware files, if they are there it looks like it’s suppposed to be supported in the kernel. Probably only Sam knows.
Edit: just a thought - you do have a lot of stuff hanging off USB. Could you try with just the dongle attached in case it’s just not getting enough power?
I’m using a powered usb hub because the RPi couldn’t supply the power directly needed to run my Passport HHD.
I did have a keyboard dongle and a usb drive plugged directly into RPi. I removed them from the RPi and rebooted Kodi. It stopped a message popping up at startup that the TVHeadend HSTP Client was unavailable.
I still do not see the Hauppauge tuner in the TVHeadend server setup. I’m going to read up a bit more on the server setup process. It doesn’t seem very intuitive or user friendly. So I may just be misunderstanding how to access the tuner.
If the tuner doesn’t show up in Configuration->DVB Inputs->TV Adapters in the TVH Webui it is not currently supported. I think someone’s looking into that for you.
