I updated 2 Vero’s to the November update yesterday, and now both units are failing on updating TV Shows with a Python script error. Cannot recall the last time I ran a Library update , but perhaps a week ago. So I cannot be sure this is related to the Nov. update.
The “Process Directory” does not exist warning , is false.
2024-11-06 21:27:00.579 T:3067 info : VideoInfoScanner: Starting scan …
2024-11-06 21:27:00.828 T:3067 warning : Process directory ‘/mnt/fred_drv1/TV Shows/Banshee/’ does not exist - skipping scan.
2024-11-06 21:27:12.094 T:3077 error : EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<–
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <class ‘NameError’>
Error Contents: name ‘TMDB_CLOWNCAR’ is not defined
File “/home/osmc/.kodi/addons/metadata.tvshows.themoviedb.org.python/main.py”, line 27, in
from libs.actions import router
File “/home/osmc/.kodi/addons/metadata.tvshows.themoviedb.org.python/libs/actions.py”, line 30, in
from . import tmdb, data_utils
File “/home/osmc/.kodi/addons/metadata.tvshows.themoviedb.org.python/libs/tmdb.py”, line 26, in
from . import cache, data_utils, api_utils, settings, imdbratings, traktratings
File “/home/osmc/.kodi/addons/metadata.tvshows.themoviedb.org.python/libs/data_utils.py”, line 30, in
from . import settings, api_utils
File “/home/osmc/.kodi/addons/metadata.tvshows.themoviedb.org.python/libs/settings.py”, line 107, in
IMAGEROOTURL, PREVIEWROOTURL = _load_base_urls()
File “/home/osmc/.kodi/addons/metadata.tvshows.themoviedb.org.python/libs/settings.py”, line 43, in _load_base_urls
conf = _get_configuration()
File “/home/osmc/.kodi/addons/metadata.tvshows.themoviedb.org.python/libs/settings.py”, line 34, in _get_configuration
return api_utils.load_info(‘https://api.themoviedb.org/3/configuration’, params={‘api_key’: TMDB_CLOWNCAR}, verboselog=VERBOSELOG)
NameError: name ‘TMDB_CLOWNCAR’ is not defined
–>End of Python script error report<–
