Hello,
I’ve had some troubles with channel icons in the past, and I’m back again, hat in hand. I’ve been careful, I think, to apply everything I’ve learned on this topic and my system is not behaving as it was in the past. Here is my current situation.
Some time ago, I noticed that the icon for a certain channel was not correct. It turns out that the associated station changed its network affiliation and hence its icon. I went through the process of downloading channel icons from their source and forcing a refresh in NextPVR. As a result, the correct icon displayed in NextPVR.
Next, I turned to Kodi, which I have running on the same Windows 10 PC on which NextPVR is running. I went to the kodi directory …/pvr.nextpvr and deleted all the .png files there. Then I chose to “Clear data” in Kodi, closed Kodi, then restarted it. As a result, the correct channel icon displayed for the subject channel.
Heady with success, I turned to OSMC running on the RPi 3B and performed exactly the same steps that I had performed in Kodi on Windows 10. Alas, upon deleting .png files from …/pvr.nextpvr, selecting Clear data, and restarting OSMC, the correct icon did not display in the guide or when I selected PVR/LiveTV>Channels and scrolled to the subject channel. However, when I navigate to Settings>LiveTV>General>Channel manager then scroll to the subject channel, I see the correct icon for that channel.
Thus, the icon for this channel is displayed inconsistently in OSMC, but not in Kodi. I suspect that there is something very simple I’m missing here, but I’ve scratched my head for a couple hours now and I can’t figure out what it might be.
Uploaded logs are here: paste.osmc.tv/usevuvizil
Thanks very much for any assistance.
