Two questions from prospective purchaser
Hello,
have a couple of questions. First is will the Vero V do DV with my projector. Its a Nebula X1. Brand new. Has 3 modes of Dolby Bright, Dark and Vivid.
Second. Currently having issue with my Zidoo Z9X box where HDR and SDR are fine but DV has a raised black floor. I’m being told I might need a custom Edid. Does the Vero V support that?
First: should do, but does it support ‘Standard DV’? Without that you will be limited to HDR10 output although Profile 5 will play with the correct colours.
Second: Yes, you can load a custom EDID but I can’t think it would solve that problem. Where are you getting that advice? We could answer both questions better if you can post the EDID here. I don’t know how to do that on a Zidoo.
This is the edid
00 FF FF FF FF FF FF 00 05 72 30 00 01 00 00 00 0A 18 01 03 80 73 41 78 0A CF 74 A3 57 4C B0 23 09 48 4C 00 00 00 01 01 01 FF 01 FF FF 01 01 01 01 01 01 01 01 20 04 74 00 30 F2 70 5A 80 B0 58 8A 00 20 C2 31 00 00 1E 02 3A 80 18 71 38 2D 40 58 2C 45 00 C4 8E 21 00 00 1E 00 00 00 FC 00 4E 45 42 55 4C 41 20 58 31 0A 20 20 20 00 00 00 FD 00 3B 46 1F 8C 3C 00 0A 20 20 20 20 20 20 01 7F 02 03 6C F2 5B 05 84 03 01 12 13 14 16 07 90 1F 20 22 5D 5F 60 61 62 64 65 66 5E 63 02 06 11 15 29 09 7F 07 15 07 50 51 06 00 83 01 00 00 E2 00 FF 72 03 0C 00 20 00 78 44 20 C0 84 01 02 03 04 01 41 00 00 67 D8 5D C4 01 78 80 07 E3 05 FF 01 E5 0F 00 80 19 00 E3 06 0F 01 E5 01 8B 84 90 01 EB 01 46 D0 00 4D 83 32 3A A4 CB 3B 8C 0A D0 8A 20 E0 2D 10 10 3E 96 00 C4 8E 21 00 00 18 00 AC
That tells us Standard DV is supported. Vero V will be happy with that.
That tells us quantization range is selectable for both YUV and RGB output. Maybe your Zidoo is sending the wrong HDMI signal?
Sorry, when you asked the same question last year, I didn’t realise you didn’t own a Vero. But I guess you didn’t have the X1 either :slight_smile:
No not yet. Just got the X1. The black floor is wrong with DV currently and everything else is working. I’ll try custom edid. That’s why I wanted to confirm this could do it if needed.
