Can I use a second remote on a Vero 4K? I have wired it to two different tv’s in my house with a HDMI splitter switch, but I don’t want bring the remote to the other room
remote works on both locations, have tested it (range).
Yes. Just make sure you pair each independently (ie without the other dongle plugged in) and you should be OK.
Keep in mind that this isn’t supported on Vero V out of the box (if you upgrade), but can be made to work.
