Hi there,
I’m running a Vero4k+ with the latest June update. 4k movies play back the way they should with the 4k finally arriving at the TV.
4k from TV/Satellite “pretend” to be 4k and the system’s information confirms that but my TV says 1080p. Everything else is OK.
Does anyone know how to fix that?
reproduce the issue
Thank you for the how-to.
I followed the instructions, turned on the logging, played 10 secs of a UHD movie and then 10 secs of a UHD TV recording.
When sending the log files form “myOSMC” it worked to 100% but then I got the message
“Could not retrieve URL, want to save to SD-card” something like that, I am running kodi with the German localization.
What now?
Thank you for the information.
Unfortunately this happens with an empty whitelist as well. As there is no entry for 3840/2160 @ 50Hz it does not seem possible to watch UHD TV in full scale with vero4k+.
Thank you for pointing me in the right direction. Connecting vero4k directly to the TV works. Both media are played at the correct scale of 3840/2160. So the culprit is my Denon A/V Receiver and NOT vero4k.
Thanks again, I’ll have a word with the Denon guys.
Michael
It could be that your AVR doesn’t support that much bandwidth. It could also be that there is an option that you have to enable in the AVR’s menus. If not supported there is still a possibility that you can get away with it anyway with a bit of tweaking, but I would look into if your AVR is actually claiming support for 4K@>30hz.
“Limited” is the format that virtually every video is stored in and that the TV expects to receive. If you output full range then, at best, the source will have to convert from limited to full and the TV will convert it back again - which will likely introduce subtle colour and luminance errors - and at worst you may even lose near-blacks and near-whites entirely.
The only displays that expect a full-range signal are things like computer monitors - devices that are primarily designed for use with a PC. They often prefer RGB rather than YUV as well. For a domestic TV you want limited YUV.
