I have a Vero 4K running the October 2022.10-1 update, connected to an LG 4K OLED TV.
Some UHD titles are skipping frames within a few seconds of playback starting, and then pausing while buffering a few minutes later. The issue continues throughout the film (at least until I give up and hit stop).
I’ve noticed this has started within the past couple of months, and the main files affected seem to be Arrow UHDs. The files are stored on a WD NAS, connected via fstab configured nfs. All devices are connected via CAT6 cables.
I would have thought this would be adequate to playback UHD content on the Vero 4K, so I’m not sure if it’s a configuration issue or a problem with the files.
Briefly, I’d suggest using iPerf3 to check your network speed (and retries) between the Vero and your NAS. Does the same thing happen with 1080p titles ?
Thanks very much for the linked thread. iPerf3 shows the Vero 4K is receiving across the network at a steady 94.1 Mbits/sec, and transmit fluctuates between 91.7 and 97.5 Mbits/sec.
I’m unable to run iPerf3 on the NAS as it doesn’t allow third party apps, so I’m transmitting & receiving between Vero 4K and PC, which are all connected by the same single gigabit network switch as the NAS.
The problem only seems to affect certain UHD titles. 1080p files (and below) play back fine. This makes me think that the affected files have a very high bitrate, so I assume a Vero 4K+ (with gigabit ethernet) should eliminate the buffering.
If anyone knows for sure, it would be nice to be certain it’s a bandwidth issue which can only be solved by upgrading the device - but I’m still happy to support OSMC by purchasing a Vero 4K+, as I’ve already had many happy years of using my original Vero 4K.
Whilst playing a video, if you hold down (long press) the HOME button on the OSMC remote this should bring up a small debug display in the top lefthand corner of your display/TV, where you can monitor the ‘real time’ bit rate (at least it does for the Vero 4K+)
Try using some of the 4K 2160p test .mkv files here (with a range of bit rates) to detect at what bit rates the buffering starts to occur.
Try WiFi first – make sure to disconnect Ethernet as we prioritise traffic over Ethernet by default. With a 5Ghz network you should easily get around 200Mbps throughput which should be sufficient for 4K UHD content.
