Upgrading my bluetooth device, I ran into an issue with no sound on my Vero4K+ out of the blue (had been working for months).
Unable to solve, I upgraded to Kodi19 via the buster-devel repository, and Kodi is operating properly.
Reading the new information for bluez-alsa, I believe the correct packages are installed.
osmc@osmc-sam:~$ dpkg -l | grep osmc | grep blue
ii armv7-bluez-osmc 5.43-6 armhf bluez for OSMC
ii armv7-bluezalsa-osmc 3.1.0-2 armhf Bluetooth audio streaming for OSMC
Using bluetoothctl, I’ve been able to pair and connect with my device no problem, and I’ve created and .asoundrc file for this device. However, in Kodi, there’s no option to output to my bluetooth device. When I enable debug logs and take a look, I see this:
2021-07-30 17:47:29.260 T:3247 INFO <general>: CAESinkALSA - Unable to open device "mybtdevice" for playback
2021-07-30 17:47:29.262 T:3247 INFO <general>: CAESinkALSA::EnumerateDevice - device hdmi:CARD=AMLMESONAUDIO,DEV=0 description AML-MESONAUDIO,
HDMI Audio Output
2021-07-30 17:47:29.262 T:3247 DEBUG <general>: CAESinkALSA - Unable to obtain ELD information for device "hdmi:CARD=AMLMESONAUDIO,DEV=0" (not supported by device, or kernel older than 3.2)
2021-07-30 17:47:29.263 T:3247 INFO <general>: CAESinkALSA - Unable to open device "usbstream:CARD=AMLMESONAUDIO" for playback
2021-07-30 17:47:29.263 T:3247 INFO <general>: Found 1 Lists of Devices
2021-07-30 17:47:29.263 T:3247 INFO <general>: Enumerated ALSA devices:
2021-07-30 17:47:29.263 T:3247 INFO <general>: Device 1
2021-07-30 17:47:29.263 T:3247 INFO <general>: m_deviceName : default
2021-07-30 17:47:29.263 T:3247 INFO <general>: m_displayName : Default (AML-MESONAUDIO: HDMI, S/PDIF & analogue)
2021-07-30 17:47:29.263 T:3247 INFO <general>: m_displayNameExtra:
2021-07-30 17:47:29.263 T:3247 INFO <general>: m_deviceType : AE_DEVTYPE_PCM
2021-07-30 17:47:29.263 T:3247 INFO <general>: m_channels : FL, FR, UNKNOWN1, LFE, FC, BC, BL, BR, BLOC, BROC
2021-07-30 17:47:29.263 T:3247 INFO <general>: m_sampleRates : 32000,44100,48000,64000,88200,96000,176400,192000
2021-07-30 17:47:29.263 T:3247 INFO <general>: m_dataFormats : AE_FMT_S24NE4,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
2021-07-30 17:47:29.263 T:3247 INFO <general>: m_streamTypes : No passthrough capabilities
2021-07-30 17:47:29.263 T:3247 INFO <general>: Device 2
2021-07-30 17:47:29.263 T:3247 INFO <general>: m_deviceName : hdmi:CARD=AMLMESONAUDIO,DEV=0
2021-07-30 17:47:29.263 T:3247 INFO <general>: m_displayName : AML-MESONAUDIO
2021-07-30 17:47:29.263 T:3247 INFO <general>: m_displayNameExtra: HDMI
2021-07-30 17:47:29.263 T:3247 INFO <general>: m_deviceType : AE_DEVTYPE_HDMI
2021-07-30 17:47:29.263 T:3247 INFO <general>: m_channels : FL, FR, BL, BR, FC, LFE, SL, SR
2021-07-30 17:47:29.263 T:3247 INFO <general>: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
2021-07-30 17:47:29.264 T:3247 INFO <general>: m_dataFormats : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW
2021-07-30 17:47:29.264 T:3247 INFO <general>: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_MA,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
2021-07-30 17:47:29.264 T:3248 INFO <general>: CActiveAESink::OpenSink - initialize sink
2021-07-30 17:47:29.264 T:3248 DEBUG <general>: CActiveAESink::OpenSink - trying to open device ALSA:default
2021-07-30 17:47:29.264 T:3248 INFO <general>: CAESinkALSA::Initialize - Requested layout: FL, FR
2021-07-30 17:47:29.264 T:3248 INFO <general>: CAESinkALSA::Initialize - set digital_codec 0
2021-07-30 17:47:29.264 T:3248 DEBUG <general>: CAESinkALSA::Initialize -- unmuting HDMI
2021-07-30 17:47:29.265 T:3248 INFO <general>: CAESinkALSA::Initialize - Attempting to open device "default"
2021-07-30 17:47:29.271 T:3248 INFO <general>: CAESinkALSA::Initialize - Opened device "default"
The device “mybtdevice” is described in my .asoundrc file:
pcm.mybtdevice {
type bluealsa
device "10:D0:7A:B2:57:22"
profile "a2dp"
hint { show on description "BT-Headphones"}
I don’t understand why Kodi is unable to open the “mybtdevice”. Could I ask for some help?
