I’ve tried to mount a shared folder using this how-to description , but I can’t get it to work. I’ve tried changing the version, the users.
I added this row to fstab: //192.168.0.13/Kodi /mnt/proba cifs x-systemd.automouint,noauto,rw,iocharset=utf8,username=mark,password=asdasd,uid=osmc,gid=osmc,file_mode=0770,dir_mode=0770,vers=3.0 0 0
When cd into /mnt/proba i get this msg:
-bash: cd: /mnt/proba/: No such device
Running smbclient -L with the flags returns this:
OS=[Windows 10 Home 17763] Server=[Windows 10 Home 6.3]
Sharename Type Comment
ADMIN$ Disk Távfelügyelet
C$ Disk Alapértelmezett megosztás
D$ Disk Alapértelmezett megosztás
IPC$ IPC Távoli IPC
Kodi Disk
Users Disk
Connection to 192.168.0.13 failed (Error NT_STATUS_RESOURCE_NAME_NOT_FOUND)
NetBIOS over TCP disabled – no workgroup available
Any idea? Am i using wrong user/pw for authentication?
I’m gonna try it afternoon. Btw what username and password should I use? Is it my windows username and password? If i create a new user and allow this user to read my shared folders in Windows then from my vero should I use the credentials of this user? Thanks in advance.
The credentials are for the share you are connecting to so in your case it would be for one of the users on the Windows machine. You can use the user/pass of any user account on the Windows machine (other than guest or admin) and it does not matter if they are logged in or not.
