Hi.
I’m unable to play the following files. They play fine on my ancient i3 windows10 in vlc with hardly any cpu use. They play fine on a cheap android s905 box running coreELEC, but only after I “Enable HEVC seek workaround” under the coreELEC settings. I can’t seem to find any similar setting on the vero 4k+ ?
Is there anything I’m doing wrong, or anything I can do?
Thanks.
Format : Matroska
Format version : Version 4
File size : 219 MiB
Duration : 24 min 25 s
Overall bit rate : 1 251 kb/s
Video
Format : HEVC
Format profile : Main@L5.1@Main
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 1 042 kb/s
Width : 1 554 pixels
Height : 1 080 pixels
Display aspect ratio : 1.439
Frame rate mode : Constant
Standard : NTSC
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.026
Stream size : 182 MiB (83%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Duration : 24 min 24 s
Bit rate : 206 kb/s
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Delay relative to video : 20 ms
Stream size : 35.9 MiB (16%)
Title : English 5.1 Surround
Language : English
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Duration : 23 min 56 s
Bit rate : 101 b/s
Count of elements : 620
Stream size : 17.9 KiB (0%)
Title : English
Language : English
Default : No
Forced : No
Text #2
Format : UTF-8
Bit rate : 110 b/s
Count of elements : 683
Stream size : 19.3 KiB (0%)
Title : English
Language : English
Default : No
Forced : No
Menu
00:00:00.000 : en:00:00:00.000
00:02:19.056 : en:00:02:19.056
00:02:52.422 : en:00:02:52.422
00:09:37.535 : en:00:09:37.535
00:14:01.049 : en:00:14:01.049
00:22:57.376 : en:00:22:57.376
00:23:57.978 : en:00:23:57.978
