I’ve been meaning to post this for a while. I have some recordings made with TV Headend v4.2 that are from BBC1 HD in the UK with DD5.1 audio that are unable to play on the Vero 4k.
As soon as you click play the first frame of the programme appears and then pauses while the percentage indicator climbs round to 100 and then hangs there.
I’ve uploaded some debug logs and here is the mediainfo for the file:
General
Unique ID : 308972378677088067617099896594653491861 (0xE871EA654DCFBBFCF705A10F827BB295)
Complete name : \192.168.1.6\Media\Videos\Howards End (2017)\Howards End.S01E01.mkv
Format : Matroska
Format version : Version 4 / Version 2
File size : 1.45 GiB
Duration : 55 min 47 s
Overall bit rate : 3 715 kb/s
Movie name : Howards End
Encoded date : UTC 2017-12-31 15:14:47
Writing application : mkvmerge v19.0.0 (‘Brave Captain’) 64-bit
Writing library : libebml v1.3.5 + libmatroska v1.4.8
Original source form : TV
Comment : Auto recording
DATE_BROADCASTED : 2017-11-12 21:00:00
SUMMARY : 1/4. Four-part adaptation of EM Forster’s classic novel. The lives of the Schelgel and Wilcox families become entwined when Margaret Schelgel befriends the enigmatic Mrs Wilcox. [HD] [AD,S]
TVCHANNEL : BBC ONE HD
Video
Format : AVC
Format profile : High@L4
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 4 frames
Codec ID : V_MPEG4/ISO/AVC
Duration : 55 min 45 s
Bit rate : 3 545 kb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.068
Stream size : 1.38 GiB (95%)
Language : English
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio #1
Format : AAC
Format/Info : Advanced Audio Codec
Format profile : LC
Codec ID : A_AAC-2
Bit rate : 124 kb/s
Channel(s) : 6 channels
Channel positions : Front: L C R, Side: L R, LFE
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Delay relative to video : -767 ms
Stream size : 49.4 MiB (3%)
Language : English
Default : Yes
Forced : No
Audio #2
Format : AAC
Format profile : HE-AAC / LC
Format settings : Explicit
Codec ID : A_AAC-2
Duration : 52 min 51 s
Bit rate : 38.1 kb/s
Channel(s) : 1 channel
Channel positions : Front: C
Sampling rate : 48.0 kHz / 24.0 kHz
Frame rate : 23.438 FPS (1024 SPF)
Delay relative to video : 6 s 578 ms
Stream size : 14.4 MiB (1%)
Language : English
Default : No
Forced : No
Text
Format : DVB Subtitle
Muxing mode : zlib
Codec ID : S_DVBSUB
Codec ID/Info : Picture based subtitle format used on DVBs
Duration : 55 min 43 s
Bit rate : 14.9 kb/s
Count of elements : 1327
Stream size : 5.93 MiB (0%)
Language : English
Default : Yes
Forced : No
Menu
