I’ve reinstalled OSMC alpha 4 on the Pi 2. I’ve been trying to connect my ethernet ready TV to the internet using the Raspberry Pi 2.
The tutorial I followed used an interfaces file in /etc/network. However, I understand from Sam that the file used here is ConnMan under /etc rather than interfaces.
I’m manually allocating the following IPs: eth0 192.168.2.1 netmask 255.255.255.0; wlan0 192.168.15.1. netmask 255.255.255.0.
My sysctl returns net.ipv4.ip_forward = 1. Pinging 192.168.2.2 and pinging 192.168.15.1 both work fine and there’s no packet loss. TV has a manual IP set as 192.168.2.2.
netstat -rn output:
Kernel IP routing table
Destination Gateway Genmask Flags MSS Window irtt Iface
0.0.0.0 192.168.15.1 0.0.0.0 UG 0 0 0 wlan0
192.168.2.0 0.0.0.0 255.255.255.0 U 0 0 0 eth0
192.168.15.0 0.0.0.0 255.255.255.0 U 0 0 0 wlan0
192.168.15.1 0.0.0.0 255.255.255.255 UH 0 0 0 wlan0
iptables -v -L output:
Chain INPUT (policy ACCEPT 366 packets, 36259 bytes)
pkts bytes target prot opt in out source destination
Chain FORWARD (policy ACCEPT 0 packets, 0 bytes)
0 0 ACCEPT all -- eth0 wlan0 anywhere anywhere
0 0 ACCEPT all -- wlan0 eth0 anywhere anywhere state RELATED,ESTABLISHED
Chain OUTPUT (policy ACCEPT 220 packets, 25304 bytes)
iptables -t nat -v -L output:
Chain PREROUTING (policy ACCEPT 9 packets, 2048 bytes)
Chain INPUT (policy ACCEPT 9 packets, 2048 bytes)
Chain OUTPUT (policy ACCEPT 50 packets, 4245 bytes)
Chain POSTROUTING (policy ACCEPT 9 packets, 524 bytes)
110 9004 SNAT all -- any wlan0 anywhere anywhere to:192.168.15.6
0 0 SNAT all -- any wlan0 anywhere anywhere to:192.168.15.6
The eth0 tcpdump on the pi and ping from laptop returns:
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
^C
0 packets captured
0 packets received by filter
0 packets dropped by kernel
However, other times it returned:
^C20:15:58.071481 IP Brunos-MacBook-Pro.local > osmc.local: ICMP host 192.168.2.11 unreachable, length 36
1 packet captured
2 packets received by filter
1 packet dropped by kernel
The Pi wlan0 tcpdump returns the following when pinging 8.8.8.8 from the laptop:
listening on wlan0, link-type EN10MB (Ethernet), capture size 262144 bytes
^C
0 packets captured
1 packet dropped by interface
On all occasions I have to halt the tcpdump on the pi with ctrl+C.
How can I get the 192.168.15.1 network to provide an internet connection to the TV on 192.168.2.2 and have this automated?
Also, thank you Sam and Mariusz for getting me this far as I clearly have limited command of the Pi!
