I have the YouTube add-on installed, I am logged in with the proper API keys in place. Everything was working fine for at least 10 days after setup and then I started getting errors whenever I use any feature of YouTube. I cannot do searches, watch content saved to Watch Later or videos in History. I saved the error log and I have pasted the portion I thought was relevant below. I dont see a way to attach the entire error log or I would have.
T:1542447840 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<–
- NOTE: IGNORING THIS CAN LEAD TO MEMORY LEAKS!
Error Type: <type ‘exceptions.ValueError’>
Error Contents: time data u’2020-04-18T02:29:28Z’ does not match format ‘%Y-%m-%dT%H:%M:%S.%fZ’
File “/home/osmc/.kodi/addons/plugin.video.youtube/resources/lib/default.py”, line 15, in
runner.run(provider)
File “/home/osmc/.kodi/addons/plugin.video.youtube/resources/lib/youtube_plugin/kodion/runner.py”, line 60, in run
RUNNER.run(provider, context)
File “/home/osmc/.kodi/addons/plugin.video.youtube/resources/lib/youtube_plugin/kodion/impl/xbmc/xbmc_runner.py”, line 33, in run
results = provider.navigate(context)
File “/home/osmc/.kodi/addons/plugin.video.youtube/resources/lib/youtube_plugin/kodion/abstract_provider.py”, line 100, in navigate
result = method(context, re_match)
File “/home/osmc/.kodi/addons/plugin.video.youtube/resources/lib/youtube_plugin/kodion/register_provider_path.py”, line 19, in wrapper
return func(*args, **kwargs)
File “/home/osmc/.kodi/addons/plugin.video.youtube/resources/lib/youtube_plugin/youtube/provider.py”, line 464, in _on_channel_playlist
result.extend(v3.response_to_items(self, context, json_data))
File “/home/osmc/.kodi/addons/plugin.video.youtube/resources/lib/youtube_plugin/youtube/helper/v3.py”, line 269, in response_to_items
result.extend(_process_list_response(provider, context, json_data))
File “/home/osmc/.kodi/addons/plugin.video.youtube/resources/lib/youtube_plugin/youtube/helper/v3.py”, line 253, in _process_list_response
live_details=is_upcoming, use_play_data=use_play_data)
File “/home/osmc/.kodi/addons/plugin.video.youtube/resources/lib/youtube_plugin/youtube/helper/utils.py”, line 292, in update_video_infos
video_item.set_aired_utc(utils.datetime_parser.strptime(snippet[‘publishedAt’]))
File “/home/osmc/.kodi/addons/plugin.video.youtube/resources/lib/youtube_plugin/kodion/utils/datetime_parser.py”, line 176, in strptime
return datetime(*time.strptime(s, fmt)[:6])
File “/usr/lib/python2.7/_strptime.py”, line 478, in _strptime_time
return _strptime(data_string, format)[0]
File “/usr/lib/python2.7/_strptime.py”, line 332, in _strptime
(data_string, format))
ValueError: time data u’2020-04-18T02:29:28Z’ does not match format ‘%Y-%m-%dT%H:%M:%S.%fZ’
–>End of Python script error report<–
