riker1
12 October 2017 07:54
1
I wanted to create a log
using
grab-logs -A
but had a problem
Unable to write temporary log to /var/tmp/uploadlog.txt
even so this file does exists
could create it with sudo and changed access to 777.
I upgraded to OSMC 18.1 but kodi is not starting.
only the sad smily…
thanks for your help
riker1:
using
grab-logs -A
but had a problem
only the sad smily…
Sounds like a filesystem problem. Try instead:
dmesg | paste-log
cat .kodi/temp/kodi.log | paste-log
riker1
12 October 2017 07:59
3
hi thanks
indeed, looks like a space problem
will check
riker1
12 October 2017 08:16
4
worked
looks like the space problem was the root cause that kodi is not starting.
will check now the nightly kodi
Which would also explain why the grab-logs couldn’t write the file
riker1
12 October 2017 09:20
6
I still can not manage to upgrade to Kodi 18.
still running 17.8 after
I did comment this line and
#deb http://apt.osmc.tv jessie main
added
deb Index of /osmc/osmc/download/dev/gmc-18 ./
to apt sources
osmc@DEVosmc96RPI2:~$ sudo apt-get install rbp2-mediacenter-osmc
Reading package lists… Done
Building dependency tree
rbp2-mediacenter-osmc is already the newest version.
and
sudo apt-get dist-upgrade
Version: 17.8-114
How do I get 18.1 nightly get installed?
thx
Don’t comment this deb http://apt.osmc.tv jessie main!
Just add deb http://download.osmc.tv/dev/gmc-18 ./ additionally
riker1:
Version: 17.8-114
this is Kodi 18! It is just named as 17.8!
riker1
12 October 2017 09:26
8
ok perfect, thanks, than it worked:slight_smile:
riker1
12 October 2017 09:27
9
by the way do you know this issue?
Use of uninitialized value in hash element at /usr/bin/apt-show-versions line 578, line 3167.
this appeared just recently while upgrading
riker1
12 October 2017 09:31
11
ok, checking with goggle. Thanks for the support
