Unfolded Circle Remote 3
Hi All,
Just purchased a Vero 5, waiting for it to arrive. I have the Unfolded Circle Remote 3. Is anyone using one with the Vero 5? Is it a straightforward setup?
I use the Unfolded Circle Remote Two without issue. Just make sure you update to the latest firmware on the remote (you may need to enable beta updates to do this). Then install the community integration for Kodi.
Thank you, will give it a try when it arrives!!
