Unifi controller *and* OSMC?
I see this has been asked before, but for Vero hardware.
Has anyone managed to get a Unifi controller working on the same RPi hardware as OSMC is running? If it’s straightforward then I can probably handle it, but if it’s a little off piste, I will likely need a tutorial.
Hardware is a RPi3 that some friends have currently setup as a Unifi controller, so I’d be wiping that and starting over.
OR
Should I just stick with it as it is now, and pull Kodi down to it as it’s already running Raspbian?
Should work just fine
Cheers Sam, I’ll give it a try.
Be reminded that Unifi Controller is very Memory demanding. Running it in parallel to Kodi (with addons) can lead to issues depending on your memory
I gave up trying after a few hours today. I’ve just stuck the unifi controller on their laptop instead :slight_smile:
