hi all,
wondering if someone can recommend a fix.
a few days ago I was playing with bluetooth packages due to issues, was in a bit of a hurry don’t recall seeing any error messages, but clearly there was. didnt think much of it at the time. recently tried to install telnet client, but getting the following which is having an affect on updates, etc.
osmc@osmc-gee:~$ sudo apt-get install telnet
Reading package lists… Done
Building dependency tree
You might want to run ‘apt --fix-broken install’ to correct these.
blueman : Depends: obexd-client (>= 0.47) but it is not installable or
bluez-obexd but it is not going to be installed
Depends: obexd-server (>= 0.47) but it is not installable or
E: Unmet dependencies. Try ‘apt --fix-broken install’ with no packages (or specify a solution).
then attempted a fix:
osmc@osmc-gee:~$ sudo apt --fix-broken install
Correcting dependencies… Done
The following additional packages will be installed:
bluez-obexd
bluez-obexd
0 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
1 not fully installed or removed.
Need to get 0 B/177 kB of archives.
After this operation, 377 kB of additional disk space will be used.
(Reading database … 73865 files and directories currently installed.)
Preparing to unpack …/bluez-obexd_5.43-2+deb9u1_armhf.deb …
Unpacking bluez-obexd (5.43-2+deb9u1) …
dpkg: error processing archive /var/cache/apt/archives/bluez-obexd_5.43-2+deb9u1_armhf.deb (–unpack):
trying to overwrite ‘/usr/share/dbus-1/services/org.bluez.obex.service’, which is also in package armv7-bluez-osmc 5.43-3
files owned by multiple packages. could try remove armv7-bluez-osmc 5.43-3 and then bluez-obexd and check status, re-install armv7-bluez-osmc 5.43-3 again?
have attempted apt-get install -f & dpkg -configure -a, but ran into the same error.
system is not too customized; transmission/samba from local builds + openvpn. been very stable otherwise.
appreciate the thoughts.
Peace, nacro.
