Got to Australia quickly - that’s great (+4 days regular australia post parcel mail though - slower than the international).
Plugged it in. It’s now in an infinite bootloop with 2 lines of white text at the top of the screen (unreadable as it flashes by too quickly with ~10 second wait with the blue unhappy face before it flashes by again). Looks vaguely like a memory address, though each line seems to begin with '207".
This occurred immediately after the setup routine reached the “Set Time” thing (mentioning HTTP) - very early in the setup process in other words.
Happens with or without Vero 4K HDMI cable, USB disk or LAN (no infra red). Haven’t tried w/out the remote wireless receiver.
Any fixes out there? My microSD cards are all old and have all failed - won’t have another to reinstall OS until tomorrow. I’d appreciate any opinions - in the meantime i’ll just let it run - those white text numbers ARE changing (for the short time i checked, they appeared to be reducing: 207.6-something, down to 207.3 etc).
Thanks - error occurs with/out LAN. USB k/b possible. Error actually occurs after a msg that contains ‘update’ and ‘utmp’ or something similar (i just disconnected/reconnected w/out usb of any kind).
Thanks everyone, a reinstall from microSD (using the toothpick+rename-to-recovery method) did the trick, and very very quickly too.
I can’t help but think i must have powered up briefly before i had everything connected, and unplugged abruptly, and caused this hassle by myself - will follow future instructions more carefully in future.
I am glad this is now working for you. It does sound like the device was initially corrupted and this can happen from abrupt power loss on the first boot.
