Unstable vero5, random reboots, crashes, freezes? Replace power supply!
What exactly is glitching?
I’d suggest posting a log so we can see what is going on. Perhaps the issue is not power supply related.
Thanks Sam.
Glitching is intermittent (but otherwise very common) freezing / stuttering and the occasional visual decoding glitch such as a block of the screen displaying different colours and blocky / garbled imagery.
The Vero V can go for weeks playing perfectly, and then not work properly for weeks, this cycle continues.
https://paste.osmc.tv/udicoqahah
Similar issues playing a different file. Note that playing the same files from an Apple TV in the same stack is fine.
2025-08-03 13:41:33.741 T:2805 debug : ------ Window Deinit (DialogSeekBar.xml) ------
2025-08-03 13:41:35.699 T:3085 debug : CPtsTracker: detected pattern of length 1: 41708.33, frameduration: 41708.333333
2025-08-03 13:42:00.786 T:3011 debug : Thread JobWorker 3648979200 terminating (autodelete)
2025-08-03 13:42:00.786 T:2966 debug : Thread JobWorker 3909079296 terminating (autodelete)
2025-08-03 13:42:00.787 T:2978 debug : Thread JobWorker 3881824512 terminating (autodelete)
2025-08-03 13:42:00.788 T:2979 debug : Thread JobWorker 3873431808 terminating (autodelete)
2025-08-03 13:44:41.393 T:3085 debug : CPtsTracker: pattern lost on diff 1001000.000000, number of losses 1
2025-08-03 13:45:09.995 T:3085 debug : CPtsTracker: detected pattern of length 1: 41708.33, frameduration: 41708.333333
Hi Paul,
This doesn’t really tell us a lot, so I checked the full log.
Please change resolution to 1080p and Adjust Refresh Rate to Always as a test and try play Barry Lyndon again.
Your log shows:
2025-08-03 13:19:04.478 T:3050    debug <general>: CFileCache::Process - </mnt/tyrellcorp_movies/Barry.Lyndon.1975.CC.iNTERNAL.BluRay.2160p.UHD.REMUX.HEVC.10bit.DV.DTS-HD.MA.5.1-Aisha.mkv> cache completely reset for seek to position 29524588415
Change the settings as suggested above and also check for potential bandwidth issues on /mnt/tyrellcorp* share.
If you still have issues, it might be worth us splitting this thread out as this certainly doesn’t look like a power supply issue.
Agreed. Moved to:
Quick update on my issue. I took the low road for complexity and switched to wired LAN from wireless (just following a hunch) and I haven’t had a single hang in the last 3 weeks (instead of frustratingly one every 2-3 days before). I’ll keep an eye on it but if it is power related it might be worth looking at the wireless subsystem or chipset for power drain.
That’s interesting, I kept having issues even after I replaced my wall psu a year back, and it got worse during summer time (hotter). I finally hooked up oscilloscope and noticed the 3.3v and 5v rail being very unstable, especially close to wifi chip. I got rid of my problems after soldering a few extra capacitors on 5v and 3.3v rail. I never mentioned this since its a definite void of warranty lol :smiley:
FWIW: I use a few devices with WiFi daily. I haven’t seen thermals change based on that.
You already voided warranty when you put a custom heatsink on the board (from memory), so not sure why you haven’t mentioned soldering additional capacitors until now. I would be interested in your findings, although with it not being a vanilla board anymore they may be moot.
Doubt it is power related or you’d see an onset of issue before 2-3 days. I’m aware of an issue with ASUS and UniFi APs that can cause a hang on certain conditions over time. Hoping to have a solution in a couple of weeks but it’s hard to reproduce and I can’t seem to pin when/why it happens yet.
I’m on Asus so that would explain it. It’s not over time though, it’s every couple of days with high bitrate content, and the hang is a complete lockup, can only be fixed by powering off and on.
Try adjust channel width.
I think there will be a firmware update for UniFi soon.
It’s set to 20/40/80 for 5Ghz and 20/40 for 2.4Ghz. What’s the recommended setting please?
Hi @all,
I remeber that I’ve swapped the power supply of my vero 4k back in times.
Now I’m waiting for my new vero V and I wonder, if I can use the power supply that I already have.
My vero is living in a lowboard under a drawer, and it would be nice if I could only unplug the vero 4k and plug in the vero 5, without needing to crawl around in the lowboard to get the power supply out an d the new one in… :laughing:
Yes you can use a power supply from a Vero 4K to power a Vero V. Do note that the Vero V is supplied with a higher current PSU so by doing this you will have a bit lower limit on how much power that can be drawn from any connected USB devices.
Thank you for your response.
I don’t have USB devices on my vero, just ethernet, HDMI and the power supply.
However, when the vero v needs more power than the vero4k, I’ll have to check the power supply I’m currently using anyway and will probably chamge it. :+1:t4:
