Some strange SSL errors and other weirdness just appeared on my Vero4K.
First, when I switched the display to the Vero’s input, I had a blank screen. I rebooted via SSH.
The remote would not work.
I rebooted again via SSH
The log showed some SSL errors.
There was also some cpu errors.
There are 9 movie entries for something called “stream” in the library, will no date.
I clean the library, and it came up with the “keep or delete” message, but no folder name.
Here are the logs, without debug activated.
I’ll try to delete those stream entries first then submit a debug log.
My other Vero appears to not have been affected.
I tracked the “stream” library entries to one movie on my only win7 samba share. Dismounted it, ran a file check, no errors …but I moved it off the drive anyways, and rebooted the Win7 server.
Ran another clean, and all was good.
Still can’t get any fanart for those 2 movies however…even after refreshing from internet. Looks like the error is on their end.
Perhaps it’s DNS related?
Can you access them from your PC?
Could be HDMI cable related or your TV doesn’t support CEC.
You could also try power everything off at the mains for a minute. But if you’re not using CEC – it doesn’t matter.
Ya, I tried those links also, and got the images.
So I just tried refreshing the info via internet, and get the same SSL/SSH errors.
Also did a full system power cycle…same SSL/SSH errors when trying to update information.
Seems some root cert issue if you try wget on OSMC you get error.
wget https://assets.fanart.tv/fanart/movies/476669/movieposter/the-kings-man-5f468bbc989c1.jpg
--2022-02-20 11:54:43-- https://assets.fanart.tv/fanart/movies/476669/movieposter/the-kings-man-5f468bbc989c1.jpg
Resolving assets.fanart.tv (assets.fanart.tv)... 163.172.219.181
Connecting to assets.fanart.tv (assets.fanart.tv)|163.172.219.181|:443... connected.
ERROR: The certificate of ‘assets.fanart.tv’ is not trusted.
ERROR: The certificate of ‘assets.fanart.tv’ doesn't have a known issuer.
And if you do it on Ubuntu you get error
--2022-02-20 11:56:04-- https://assets.fanart.tv/fanart/movies/476669/movieposter/the-kings-man-5f468bbc989c1.jpg
ERROR: cannot verify assets.fanart.tv's certificate, issued by ‘CN=ZeroSSL RSA Domain Secure Site CA,O=ZeroSSL,C=AT’:
Unable to locally verify the issuer's authority.
To connect to assets.fanart.tv insecurely, use `--no-check-certificate'.
