I’m having a new issue where when I start to watch something, the file will play for a few seconds, then go black with no sound and then my tv will display “resolution not supported. Change the resolution of the external device”.
This error is from the tv, not the Vero. The only way to get a picture back is to reboot the Vero.
It is not consistent, so I’m wondering if it is possible that there is something wrong with a particular video file or if it could be something else.
Without logs it’s impossible to say. But if it’s only happening with one file I’d suspect that file.
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Oh, it doesn’t seem to matter what file it is. And it is only after a long pause between uses. Perhaps after a late night backup or an automatic update? After it stops working and I reboot, it seems to work fine and I can play file after file. The next day, the same problem arises.
I don’t think it’s related to the TV itself. I’m starting to think it may be the video file after all.
Okay, the TV has been off for hours, the Vero not (it’s left on all the time). I’ve been watching a particular series, so I tried playing another file and it seemed to work okay. So, I went back to my series and tried a file and after the usual 30 seconds or so, the screen goes black and then I get the resolution error warning on the screen.
What I don’t get is while this error does occur, if I reboot the Vero and go and play the exact same file, it works without issue.
I used MediaInfo to look at the video file and this is what it spat out. I don’t know if it means anything.
