Vero 4k+ manual attempt to update today, 01/01/2019.
Logs: https://paste.osmc.tv/uriqujavoq
HI,
Could you please post the output off the following, from the command line:
sudo apt-get update
sudo apt-get dist-upgrade
Thanks Tom.
osmc@bedroom:~$ sudo apt-get update
Hit:1 http://security.debian.org stretch/updates InRelease
Ign:2 Index of /debian stretch InRelease
Hit:4 Index of /debian stretch-updates InRelease
Hit:5 Index of /debian stretch Release
Hit:6 Index of linux/debian/ stretch InRelease
Hit:3 Index of /osmc/osmc/apt stretch InRelease &
Reading package lists… Done
osmc@bedroom:~$ sudo apt-get dist-upgrade
Building dependency tree
Calculating upgrade… Done
Looks good to me and all up to date.
Sorry to hijack this thread, but I’ve been also having problems with updates on Vero4k+. Even when i got Vero4k+, it wouldn’t properly update or install plugins from Kodi. If i downloaded the updates and plugins manually, it would install them without a problem.
I tried reinstalling the OS but the problem persisted. It would take a couple of tries to even get services like transmission to enable from the OSMC menu. Once they were enabled, they worked without a problem.
My output from the update commands is this:
osmc@vero4k:~$ sudo apt-get update
Get:1 htp://security.debian.org stretch/updates InRelease [94.3 kB]
Ign:2 htp://ftp.debian.org/debian stretch InRelease
Get:4 htp://ftp.debian.org/debian stretch-updates InRelease [91.0 kB]
Hit:3 htp://ftp.fau.de/osmc/osmc/apt stretch InRelease
Hit:5 htp://ftp.debian.org/debian stretch Release
Get:6 htp://security.debian.org stretch/updates/main armhf Packages [453 kB]
Get:7 htp://security.debian.org stretch/updates/main arm64 Packages [448 kB]
Get:8 htp://security.debian.org stretch/updates/main Translation-en [205 kB]
Fetched 1291 kB in 2s (577 kB/s)
Reading package lists… Doneosmc@vero4k:~$ sudo apt-get dist-upgrade
vero364-image-3.14.29-134-osmc:arm64
libudev1 mediacenter-addon-osmc udev vero3-mediacenter-osmc vero364-kernel-osmc:arm64
5 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 77.5 MB/78.7 MB of archives.
After this operation, 244 MB of additional disk space will be used.
Do you want to continue? [Y/n]
Get:1 htp://ftp.fau.de/osmc/osmc/apt stretch/main arm64 vero364-image-3.14.29-134-osmc arm64 134 [33.2 MB]
Get:2 htp://ftp.fau.de/osmc/osmc/apt stretch/main armhf mediacenter-addon-osmc all 3.0.666 [4412 kB]
Err:2 htp://apt.osmc.tv stretch/main arm64 mediacenter-addon-osmc all 3.0.666
Hash Sum mismatch
Hashes of expected file:
- SHA256:2eae4078aa2e2be2e40a9a4ceb34e4a0cd7ae1eff6ba291d3f090c04c3c06cc3
- SHA1:43b74be55ab3b740794b6e7b19d589b755c12b56 [weak]
- MD5Sum:93dc5a65f46fe00a1aed6578e5ef0b1a [weak]
- Filesize:4411814 [weak]
Hashes of received file:- SHA256:75ef7026f1ab6e22ce4ed215a94d802f1ad09662d3ad1d1171e53b23a07db492
- SHA1:3b5243656a16fb058aac19b3cbd695d1bbd7090f [weak]
- MD5Sum:37eadce8e15e1c7c55e2fbeb240586d8 [weak]
Last modification reported: Tue, 04 Dec 2018 18:59:11 +0000
Err:2 htp://ftp.fau.de/osmc/osmc/apt stretch/main armhf mediacenter-addon-osmc all 3.0.666
Hash Sum mismatch
Hashes of expected file:- SHA256:2eae4078aa2e2be2e40a9a4ceb34e4a0cd7ae1eff6ba291d3f090c04c3c06cc3
Get:3 htp://ftp.fau.de/osmc/osmc/apt stretch/main armhf vero3-mediacenter-osmc armhf 17.6.0-61 [39.9 MB]
Err:3 htp://ftp.fau.de/osmc/osmc/apt stretch/main armhf vero3-mediacenter-osmc armhf 17.6.0-61
Hash Sum mismatch
Hashes of expected file:- SHA256:502cab7cb3c0bbbdd523411bd14f4980ac10833c205ba5789ef20dc1d8ab2d45
- SHA1:e9c3b6557f0d0d5531651e0a7657618ecaa4e1ad [weak]
- MD5Sum:5184f4df37d79c9365dc3e21198df9c8 [weak]
- Filesize:39869998 [weak]
Hashes of received file:- SHA256:5064d917611ef9ce4af09afc60fd2f5ced9cb5820969805f5a1fc201640753b9
- SHA1:b6fa296cd61af3e18c6d977cea9528eda799a04d [weak]
- MD5Sum:422f2098488851ca5ba2d22b951565ba [weak]
Last modification reported: Mon, 31 Dec 2018 05:10:38 +0000
Fetched 77.5 MB in 36s (2101 kB/s)
E: Failed to fetch htp://apt.osmc.tv/pool/main/m/mediacenter-addon-osmc/mediacenter-addon-osmc_3.0.666_all.deb Hash Sum mismatch
E: Failed to fetch htp://ftp.fau.de/osmc/osmc/apt/pool/main/v/vero3-mediacenter-osmc/vero3-mediacenter-osmc_17.6.0-61_armhf.deb Hash Sum mismatch
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
(I changed http to htp because of forum link restrictions).
I tried using the --fix-missing flag but the result is the same. Update in Kodi also fails and tells me to go to these forums.
Everything else apart from the updates and plugins install works without a problem.
Anyone has any ideas? The problem is still present.
I’m sure @sam_nazarko or some other osmc staffer will help you out
All the staffers seem to busy, so you’ll have to make do with a general dogsbody, I’m afraid.
It looks like the packages were somehow corrupted when downloaded, possibly due to a network problem.
I’d suggest you try the following from the command line:
sudo apt-get clean
sudo apt-get update
Let us know how you get on.
Got the same error even after using the clean command (changed the URLs again, because of forum restrictions).
I got an Raspberry PI 2 with OSMC on the same network and that one updates fine, so I doubt it would be any kind of network issues. Plus apart from updates and installing plugins, everything else that’s network based works fine (streams, web plugins, transmission, …) on Vero4k+.
osmc@vero4k:~$ sudo apt-get clean
Get:6 htp://security.debian.org stretch/updates/main arm64 Packages [448 kB]
Get:7 htp://security.debian.org stretch/updates/main armhf Packages [453 kB]
Fetched 1086 kB in 3s (361 kB/s)
libnss-myhostname libpam-systemd libsystemd0 libudev1 mediacenter-addon-osmc systemd systemd-sysv udev vero3-mediacenter-osmc vero364-kernel-osmc:arm64
10 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 81.6 MB of archives.
Get:1 htp://security.debian.org stretch/updates/main armhf systemd-sysv armhf 232-25+deb9u8 [81.8 kB]
Get:6 htp://security.debian.org stretch/updates/main armhf libpam-systemd armhf 232-25+deb9u8 [176 kB]
Get:2 htp://ftp.fau.de/osmc/osmc/apt stretch/main arm64 vero364-image-3.14.29-134-osmc arm64 134 [33.2 MB]
Get:7 htp://security.debian.org stretch/updates/main armhf libnss-myhostname armhf 232-25+deb9u8 [103 kB]
Err:7 htp://security.debian.org stretch/updates/main armhf libnss-myhostname armhf 232-25+deb9u8
Hash Sum mismatch
- SHA256:d9091476ba32fc1bac2451353b58f1e782a2a5959f94c71f14967fa28e359cce
- SHA1:d44e6576da788d3e7ba8b2815eeff62f21ff7b83 [weak]
- MD5Sum:05364b912d9eb6b7577f3f50cb618347 [weak]
- Filesize:102654 [weak]
Hashes of received file:- SHA256:bab0a8f0f7f2c1561eb8e035e85ef5d7007ce9f4c037d0f4caf3ab11c52302e6
- SHA1:267791f904596c03500329ed71109c7e25343f88 [weak]
- MD5Sum:da13db4347a0a58727cdf947e023eec6 [weak]
Last modification reported: Tue, 15 Jan 2019 13:44:49 +0000
Get:8 htp://security.debian.org stretch/updates/main armhf libsystemd0 armhf 232-25+deb9u8 [260 kB]
Err:8 htp://security.debian.org stretch/updates/main armhf libsystemd0 armhf 232-25+deb9u8
Hash Sum mismatch
Hashes of expected file:- SHA256:e2186a096081db688c56bfc8cd803ca79f364d81d693520a52aad5aa346e4623
- SHA1:9fee3ef862235ff281e7e06624dfd0f317a8ea0d [weak]
- MD5Sum:838c10869a3d5842105a1203aab4819b [weak]
- Filesize:259820 [weak]
Hashes of received file:- SHA256:a6b6e811ab4e7ca68f03eeb6ea8444fe49fcc79f736f8fc478fe0be34c40da95
- SHA1:1ef4d33327282b521453e9189e8663d26c9b3e66 [weak]
- MD5Sum:2b1bada7730399da5c046584c43d4fef [weak]
Get:9 htp://security.debian.org stretch/updates/main armhf systemd armhf 232-25+deb9u8 [2274 kB]
Err:9 htp://security.debian.org stretch/updates/main armhf systemd armhf 232-25+deb9u8
Hash Sum mismatch
Hashes of expected file:- SHA256:94297ebc8bf03e03b80e7c727edd2e0384084496c8149232cbdbc0957bea07d6
- SHA1:e741cd3c8c3546e004e26dadb12741d68a1bcf63 [weak]
- MD5Sum:177c7adaf8b29286c8335397a71e42c6 [weak]
- Filesize:2274070 [weak]
Hashes of received file:- SHA256:d4cff796e5ffe767b7cde468bb4c1779ff1f227f1c637f61743b90a8fed3880a
- SHA1:c6a9ff1c06f32edf6f8e4ec8adb8ef0b0ab914fe [weak]
- MD5Sum:eb72c99ea6b067bfcbc0c8e8c980a360 [weak]
Get:10 htp://security.debian.org stretch/updates/main armhf udev armhf 232-25+deb9u8 [1077 kB]
Err:10 htp://security.debian.org stretch/updates/main armhf udev armhf 232-25+deb9u8
Hash Sum mismatch
Hashes of expected file:- SHA256:884ec64cdbf7016f5239172245f2de557aa22e96a337b576712e2e6fc4661cbc
- SHA1:bd0e4abc5e4cf404b239506a6b834ac533b9c2cb [weak]
- MD5Sum:5340d2a24f2512be4c300fd36b18dfac [weak]
- Filesize:1077194 [weak]
Hashes of received file:- SHA256:bfb25c9f0ce0a5a8185d71b4dc4a1c4254b0f9ac1ccb265a3fc44534a2d6b37d
- SHA1:ed25db1ded03e682d0bc74e17927e394c9e91fd0 [weak]
- MD5Sum:0732e4fd54ba439f5d7c318156eb74ce [weak]
Get:11 htp://security.debian.org stretch/updates/main armhf libudev1 armhf 232-25+deb9u8 [120 kB]
Err:2 htp://ftp.fau.de/osmc/osmc/apt stretch/main arm64 vero364-image-3.14.29-134-osmc arm64 134
Hash Sum mismatch
Hashes of expected file:- SHA256:d0277449219384722635735f08265dc957d7dc0c70ff5d6f43a91fcbe79b1e1d
- SHA1:18f62d54fcb56d990ff9c91fc1a295249b2bdabf [weak]
- MD5Sum:b6cba459e541fbf33fc04a6e54e0e718 [weak]
- Filesize:33180320 [weak]
Hashes of received file:- SHA256:2bd8841e17eee5786aaacc493fccbbc6f35fa5b9a550713ca657c942ce4debdf
- SHA1:67fdefbee4c5bc6d7fa13e35d1b69e8725147749 [weak]
- MD5Sum:09d7279431bd52d337b025f0377c1e3d [weak]
Last modification reported: Mon, 31 Dec 2018 01:32:32 +0000
Get:3 htp://ftp.fau.de/osmc/osmc/apt stretch/main armhf mediacenter-addon-osmc all 3.0.666 [4412 kB]
Err:3 htp://apt.osmc.tv stretch/main arm64 mediacenter-addon-osmc all 3.0.666
Hash Sum mismatch
Hashes of received file:- SHA256:34d0286d955108410cdb23e6540c08eafb69d05fde0f9e027ce38f993777a0b9
- SHA1:a2fe0155656c1d7eede75dba86fa090afd4a4bc4 [weak]
- MD5Sum:d6c5c24204ec227a0f20a0ae25b9e843 [weak]
Err:3 htp://ftp.fau.de/osmc/osmc/apt stretch/main armhf mediacenter-addon-osmc all 3.0.666
Hash Sum mismatch
Get:4 htp://ftp.fau.de/osmc/osmc/apt stretch/main armhf vero3-mediacenter-osmc armhf 17.6.0-61 [39.9 MB]
Err:4 htp://ftp.fau.de/osmc/osmc/apt stretch/main armhf vero3-mediacenter-osmc armhf 17.6.0-61
Hash Sum mismatch
Hashes of received file:- SHA256:5294efc27b2d535a48ff52ac541d1927732e66fa6119841128dcd625d10d70fe
- SHA1:a68a3c6e6ce60b6fb377989c78ce0940d1530039 [weak]
- MD5Sum:0c6d19422ad58e716e7bf5d67a52360d [weak]
Get:5 htp://ftp.fau.de/osmc/osmc/apt stretch/main arm64 vero364-kernel-osmc arm64 3.9.127 [964 B]
Fetched 81.6 MB in 1min 5s (1255 kB/s)
E: Failed to fetch htp://security.debian.org/pool/updates/main/s/systemd/libnss-myhostname_232-25+deb9u8_armhf.deb Hash Sum mismatch
E: Failed to fetch htp://security.debian.org/pool/updates/main/s/systemd/libsystemd0_232-25+deb9u8_armhf.deb Hash Sum mismatch
E: Failed to fetch htp://security.debian.org/pool/updates/main/s/systemd/systemd_232-25+deb9u8_armhf.deb Hash Sum mismatch
E: Failed to fetch htp://security.debian.org/pool/updates/main/s/systemd/udev_232-25+deb9u8_armhf.deb Hash Sum mismatch
E: Failed to fetch htp://ftp.fau.de/osmc/osmc/apt/pool/main/v/vero364-source-3.14.29-134-osmc/vero364-image-3.14.29-134-osmc_134_arm64.deb Hash Sum mismatch
If this is a new Vero4K+ and you’ve been having these problems from the beginning, it might be a hardware problem. However, I think the next steps should be:
- Provide full logs -
grab-logs -A - If the V4K+ is on cable, use a different cable, and choose a different port on the router.
- If you’re on cable, try WiFi and see if the problem persists.
Yeah, I’ve been having these problems from the beginning, but kinda hoped it was a bug and future updates would fix it. I ordered Vero4K+ with one of the first batches, when it came out.
Here are the logs: https://paste.osmc.tv/ecuponisah
I tried using different cables and wireless, but had the same problem. The fact, that I had trouble turning on samba and transmission (worked only after a couple of tries), tells me that network isn’t the problem. I kinda suspect that the buffer is the issue, but find it strange, that it works well with all other stuff.
Just to double check. You’re getting this on wired and wireless? (You need to have disconnected the cable for it to be a true test of wireless.)
Update: The ifconfig statistics are not good:
eth0: flags=-28605<UP,BROADCAST,RUNNING,MULTICAST,DYNAMIC> mtu 1500
inet 192.168.88.13 netmask 255.255.255.0 broadcast 192.168.88.255
ether c4:4e:ac:28:25:44 txqueuelen 1000 (Ethernet)
RX packets 5350309 bytes 6582231777 (6.1 GiB)
RX errors 0 dropped 56796 overruns 0 frame 0
TX packets 5263801 bytes 4022393512 (3.7 GiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device interrupt 40
56,796 dropped packets is very high.
You need to repeat the update/dist-upgrade using WiFi and with the cable disconnected.
Thank you for the help, you figured out the problem.
I tried switching to wireless and the updates went through, but the addons still failed. The first time i tested it, I tried with install addons, but they failed since the packages were already downloaded from the attempt with wired. Now it went fine with wireless, since I deleted all the packages downloaded before.
I also forced 100 Mbps connection on switch and it also works now via wired. Seems the problem is with 1 Gbps setting it gets when auto-negotiation is on. Haven’t seen any such problem on other devices connected to the switch, but I’ll keep a lookout and try it out with another switch, if it works normally on 1 Gbps then.
Again, thanks for all the help. This has been bugging me for a while now and I’m glad I know the reason why it’s acting up.
