Update for January failed
And after going back to 2016 and running:
I had no errors. The update only went up to 2017-10-1:
Logs available at https://paste.osmc.tv/ijujojiduv
Trying to get above 2017-10-1
Fetched 51.9 MB in 1min 23s (618 kB/s)
E: Failed to fetch http://ftp.debian.org/debian/pool/main/g/glibc/libc6_2.24-11+deb9u1_armhf.deb Hash Sum mismatch
E: Failed to fetch http://apt.osmc.tv/pool/main/v/vero2-mediacenter-osmc/vero2-mediacenter-osmc_17.6.0-22_armhf.deb Hash Sum mismatch
E: Failed to fetch http://apt.osmc.tv/pool/main/m/mediacenter-skin-osmc/mediacenter-skin-osmc_17.0.2-6_all.deb Hash Sum mismatch
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
osmc@Oswin:~$ grab-logs -A
Logs successfully uploaded.
Logs available at https://paste.osmc.tv/japikofusu
And switching to WiFi and upgrading to 2018-01-1:
Logs available at https://paste.osmc.tv/ijebemikip
Sounds like the driver then. I’ll revert to the older one.
Did you see other symptoms, so that you could verify quickly if things are fixed?
The apt-get failure was the most obvious one, but there was that other command…
Here it is: curl https://ftp.fau.de/osmc/osmc/apt/pool/main/v/vero2-mediacenter-osmc/vero2-mediacenter-osmc_17.6.0-22_armhf.deb > /dev/null
That fails on Ethernet, too.
Building.
  1. Login via the command line
  2. Edit the file /etc/apt/sources.list
  3. Add the following line: deb http://apt.osmc.tv stretch-devel main
  4. Run the following commands to update: sudo apt-get update && sudo apt-get dist-upgrade && reboot
  5. Your system should have have received the update.
After applying the new version, this command did not give any errors. (There weren’t any updates for me to try those.)
Cool. Guess we’ll find out on the next update.
I get the same error too, when cloning into the git repo. Right now I am on cable, because the wifi in my neighborhood sucks (18 Mbps down vs. less than 1 Mbps down)
EDIT: It also happens on wifi over 4G/LTE
root@KARMUS-MC:/home/osmc# git clone https://github.com/osmc/osmc
Cloning into 'osmc'...
remote: Counting objects: 62675, done.
remote: Compressing objects: 100% (52/52), done.
error: RPC failed; curl 56 GnuTLS recv error (-24): Decryption has failed.
fatal: The remote end hung up unexpectedly
fatal: early EOF
fatal: index-pack failed
From your posting history, it looks like you have a Vero4K. The issue on this thread seems to be with the ethernet driver for the Vero2.
If you’re on a Vero4K, I suggest you open a new thread. With logs, please. :wink:
