i have a Vero V. several months ago the time it takes to Update Library increased from ~30 seconds, to 3-5 minutes. it sits at “Scanning TV shows using TMDB TV Shows, 0%” forever, even when i only have 1 or 2 new episodes to scan. my media files are on a local NAS, everything is connected via ethernet. no network issues that i’m aware of. my library is pretty small, maybe just 15 TV folders. i haven’t seen anyone else complaining, so maybe it’s just me? how do i troubleshoot?
reproduce the issue
That log doesn’t show anything being scraped. I see where you started a library scan, but since there were no updated shows or episodes, the scraper never got called. A log showing a slow scrape is going to be needed to help with this.
it’s not the scraping that’s slow, it’s the scan. it was stuck scanning for a good 3+ minutes here. the actual scraping when it finds something is fast.
