I am just wondering how to auto-update without losing all the settings, A cannot seem to find it anywhere in the settings, what am I missing=
There is no auto update without losing settings.
You have to either use a Kodi backup tool/addon or manually backup the settings/databases of media.
I would personally recommend starting from scratch though. Less risk of something not working because of some setting or addon not working correct from one version to the other.
Please see my post in the RC release thread:
Thanks DBMandrake, I should have read the previous answer, sorry.
I will do a fresh install, but I guess it is okay to copy my sources.xml and keymaps.xml from the userdata folder, right?
