Dear community,
I hope you can give me some finger pointers with the following.
In order to use my Vero 4k for music playback as well, I intend to install LibreSpot plugin for SPotify (Spotify connect plugin), using following instructions: [HowTo] Spotify-Connect support via Raspotify (LibreSpot) .
# Add repo and its GPG key
curl -sSL https://dtcooper.github.io/raspotify/key.asc | sudo apt-key add -v -
echo ‘deb raspotify | A Spotify Connect client that mostly Just Works™ jessie main’ | sudo tee /etc/apt/sources.list.d/raspotify.list
# Install package
sudo apt-get update
sudo apt-get install apt-transport-https
sudo apt-get -y install raspotify
Sudo apt-get install failes with W: Failed to fetch https://dtcooper.github.io/raspotify/dists/jessie/InRelease Unable to find expected entry ‘main/binary-arm64/Packages’ in Release file (Wrong sources.list entry or malformed file)
Using the search (forum / google), I did not come across the same / any similar problem.
I would highly appreciate any feedback.
Thank you!
Dan
Just a guess that it searches for arm64 packages based on the architecture of the Vero which are not available in that repository
Use armhf, not arm64 packages.
I tried it on my Vero4K and though it produced some errors during the update stage, it should have installed correctly.
osmc@osmc:~$ sudo apt-get update
Ign http://ftp.debian.org jessie InRelease
Hit http://ftp.debian.org jessie-updates InRelease
Hit http://ftp.debian.org jessie Release.gpg
Get:1 http://ftp.debian.org jessie-updates/main arm64 Packages/DiffIndex [8884 B]
Get:2 https://dtcooper.github.io jessie InRelease [1703 B]
Ign https://dtcooper.github.io jessie InRelease
Hit http://ftp.debian.org jessie-updates/contrib arm64 Packages
Get:3 https://dtcooper.github.io jessie/main arm64 Packages [9340 B]
Get:4 http://ftp.debian.org jessie-updates/non-free arm64 Packages/DiffIndex [736 B]
Hit http://security.debian.org jessie/updates InRelease
Get:5 http://ftp.debian.org jessie-updates/main armhf Packages/DiffIndex [8884 B]
Get:6 https://dtcooper.github.io jessie/main armhf Packages [9340 B]
Hit http://ftp.debian.org jessie-updates/contrib armhf Packages
Hit http://security.debian.org jessie/updates/main arm64 Packages
Get:7 http://ftp.debian.org jessie-updates/non-free armhf Packages/DiffIndex [736 B]
Hit http://ftp.debian.org jessie-updates/contrib Translation-en
Hit http://security.debian.org jessie/updates/contrib arm64 Packages
Get:8 https://dtcooper.github.io jessie/main Translation-en [9340 B]
Get:9 http://ftp.debian.org jessie-updates/main Translation-en/DiffIndex [3688 B]
Hit http://security.debian.org jessie/updates/non-free arm64 Packages
Hit http://apt.osmc.tv jessie InRelease
Get:10 https://dtcooper.github.io jessie/main arm64 Packages [9340 B]
Get:11 http://ftp.debian.org jessie-updates/non-free Translation-en/DiffIndex [736 B]
Hit http://security.debian.org jessie/updates/main armhf Packages
Get:12 https://dtcooper.github.io jessie/main armhf Packages [9340 B]
Get:13 http://apt.osmc.tv jessie/main arm64 Packages/DiffIndex [2023 B]
Hit http://security.debian.org jessie/updates/contrib armhf Packages
Hit http://security.debian.org jessie/updates/non-free armhf Packages
Hit http://ftp.debian.org jessie/main arm64 Packages
Get:14 http://apt.osmc.tv jessie/main armhf Packages/DiffIndex [2023 B]
Get:15 https://dtcooper.github.io jessie/main Translation-en [9340 B]
Hit http://security.debian.org jessie/updates/contrib Translation-en
Hit http://ftp.debian.org jessie/contrib arm64 Packages
Get:16 https://dtcooper.github.io jessie/main arm64 Packages [9340 B]
Hit http://ftp.debian.org jessie/non-free arm64 Packages
Hit http://security.debian.org jessie/updates/main Translation-en
Hit http://ftp.debian.org jessie/main armhf Packages
Hit http://security.debian.org jessie/updates/non-free Translation-en
Get:17 https://dtcooper.github.io jessie/main armhf Packages [9340 B]
Hit http://ftp.debian.org jessie/contrib armhf Packages
Get:18 https://dtcooper.github.io jessie/main Translation-en [9340 B]
Hit http://ftp.debian.org jessie/non-free armhf Packages
Get:19 https://dtcooper.github.io jessie/main arm64 Packages [9340 B]
Hit http://ftp.debian.org jessie/contrib Translation-en
Hit http://ftp.debian.org jessie/main Translation-en
Get:20 https://dtcooper.github.io jessie/main armhf Packages [9340 B]
Hit http://ftp.debian.org jessie/non-free Translation-en
Get:21 https://dtcooper.github.io jessie/main Translation-en [9340 B]
Get:22 https://dtcooper.github.io jessie/main arm64 Packages [9340 B]
Err https://dtcooper.github.io jessie/main arm64 Packages
HttpError404
Ign http://apt.osmc.tv jessie/main Translation-en
Get:23 https://dtcooper.github.io jessie/main Translation-en [9340 B]
Ign https://dtcooper.github.io jessie/main Translation-en
Fetched 29.8 kB in 15s (1956 B/s)
W: GPG error: https://dtcooper.github.io jessie InRelease: The following signatures couldn't be verified because the public key is not available: NO_PUBKEY 09146F2F7953A455
W: Failed to fetch https://dtcooper.github.io/raspotify/dists/jessie/main/binary-arm64/Packages HttpError404
E: Some index files failed to download. They have been ignored, or old ones used instead.
osmc@osmc:~$ apt-cache show raspotify
Package: raspotify
Version: 0.9~librespot.20170804T042825Z.ddfc28f
Architecture: armhf
Depends: libasound2, adduser
Maintainer: David Cooper <david@dtcooper.com>
Priority: optional
Section: base
Filename: pool/main/r/raspotify/raspotify_0.9~librespot.20170804T042825Z.ddfc28f_armhf.deb
SHA256: f59989264d25b8d4ee21cadf569d30a9e5abdfb4eeebe8ef68c37c93e0812b5b
SHA1: 3132c721e2c38ea16e4ebfd1a747299b5ba2120b
MD5sum: 8e2bc7d1ded5ab09079948de96d5d66a
Description: Raspotify
Spotify Connect client + daemon for the Raspberry Pi, based off librespot.
[Built with rustc 1.19.0 (0ade33941 2017-07-17)]
Description-md5: 075d1dbfd9688a1cfd6733f31f1980f8
osmc@osmc:~$ sudo apt-get install raspotify --dry-run
Reading package lists... Done
Building dependency tree
raspotify
0 upgraded, 1 newly installed, 0 to remove and 22 not upgraded.
Inst raspotify (0.9~librespot.20170804T042825Z.ddfc28f dtcooper.github.io [armhf])
Conf raspotify (0.9~librespot.20170804T042825Z.ddfc28f dtcooper.github.io [armhf])
You can also download the .deb package directly: https://dtcooper.github.io/raspotify/raspotify-latest.deb which is probably the simplest option.
The Vero4K declares it has an architecture of armhf:
osmc@osmc:~$ dpkg --print-architecture
armhf
To my understanding, the package I intend to use (LibreSpot), requires the arm64 package. How can I instead use the armhf what is already existing? Any harm in installing the arm64 package in parallel?
If LibreSpot works on Pi then it won’t be ARM64.
Further to what Sam has said, where will you find the ARM64 version? There is only one download link, and that’s to the armhf version:
user@work:/tmp$ dpkg -I raspotify-latest.deb
new debian package, version 2.0.
size 1134104 bytes: control archive=1123 bytes.
23 bytes, 1 lines conffiles
344 bytes, 10 lines control
1266 bytes, 38 lines * postinst #!/bin/sh
650 bytes, 26 lines * postrm #!/bin/sh
160 bytes, 9 lines * prerm #!/bin/sh
Package: raspotify
Section: base
Priority: optional
Architecture: armhf
zilexa
21 September 2017 13:42
8
I have updated OSMC Forums [HowTo] Spotify-Connect support via Raspotify (LibreSpot) to make clear it is a Raspberry solution since Raspotify is a LibreSpot wrapper for Raspberry Pi. There is no generic/native OSMC solution (yet).
I am not a developer but anyone who wants to try can talk here about creating an OSMC app: LibreSpot in the OSMC App Store .
Let’s continue the discussion in the other thread. The first thing to do is confirm it works on other OSMC devices
