Hi.
I’m having a slight problem with updates on my 4K+. I noticed on MyOSMC that my revision is December 2021, so tried to update. Nothing happened.
I went into command line and tried to update and got the message:
osmc@Vero4KPlus:~$ sudo apt-get update
Hit:1 Index of /debian buster InRelease
Hit:2 Index of /debian buster-updates InRelease
Hit:3 http://security.debian.org buster/updates InRelease
Hit:4 Index of /osmc/osmc/apt buster InRelease
Ign:5 Index of /osmc/osmc/apt buster/main Translation-en
Err:5 Index of /osmc/osmc/apt buster/main Translation-en
404 Not Found [IP: 131.188.12.211 80]
Reading package lists… Done
W: Conflicting distribution: http://security.debian.org buster/updates InRelease (expected buster/updates but got buster-updates)
W: Conflicting distribution: Index of /osmc/osmc/apt buster InRelease (expected buster but got buster-updates)
E: Failed to fetch http://ftp.fau.de/osmc/osmc/apt/dists/buster/main/i18n/by-hash/SHA256/50fdd227e2079381c8a06d645e9f2086613e45993f71ac8fc68da3fca55ec812 404 Not Found [IP: 131.188.12.211 80]
E: Some index files failed to download. They have been ignored, or old ones used instead.
I tried the dist-upgrade and got this:
osmc@Vero4KPlus:~$ sudo apt-get dist-upgrade
Building dependency tree
Calculating upgrade… Done
vero364-image-4.9.113-64-osmc:arm64
armv7-bluez-osmc armv7-connman-osmc base-files base-files-osmc bind9-host bzip2 cifs-utils curl dirmngr distro-info-data dpkg gnupg gnupg-l10n gnupg-utils gpg gpg-agent gpg-wks-client
gpg-wks-server gpgconf gpgsm gpgv gzip libbind9-161 libbz2-1.0 libc-bin libc-l10n libc6 libcups2 libcurl4 libdns1104 libexpat1 libfreetype6 libfribidi0 libglib2.0-0 libgmp10 libgnutls30
libgssapi-krb5-2 libicu63 libisc1100 libisccc161 libisccfg163 libk5crypto3 libkrb5-3 libkrb5support0 libldap-2.4-2 libldap-common liblwres161 liblzma5 libmariadb3 libnss3 libntfs-3g883
libpolkit-agent-1-0 libpolkit-backend-1-0 libpolkit-gobject-1-0 libsasl2-2 libsasl2-modules-db libsmbclient libsqlite3-0 libssl1.1 libtiff5 libtirpc-common libtirpc3 liburiparser1 libwbclient0
libxml2 libxslt1.1 locales mariadb-common mediacenter-addon-osmc mediacenter-skin-osmc multiarch-support ntfs-3g openssl policykit-1 python-samba python3-pil samba samba-common samba-common-bin
samba-libs tzdata vero3-mediacenter-osmc vero3-wifi-osmc vero364-kernel-osmc:arm64 xz-utils zlib1g
86 upgraded, 1 newly installed, 0 to remove and 0 not upgraded.
Need to get 258 kB/180 MB of archives.
After this operation, 93.4 MB of additional disk space will be used.
Ign:1 http://security.debian.org buster/updates/main armhf mariadb-common all 1:10.3.36-0+deb10u1
Err:2 http://security.debian.org buster/updates/main armhf libmariadb3 armhf 1:10.3.36-0+deb10u1
404 Not Found [IP: 151.101.62.132 80]
Err:1 http://security.debian.org buster/updates/main armhf mariadb-common all 1:10.3.36-0+deb10u1
Ign:3 Index of /osmc/osmc/apt buster/main armhf base-files-osmc all 3.1.5
Err:3 http://apt.osmc.tv buster/main armhf base-files-osmc all 3.1.5
E: Failed to fetch http://apt.osmc.tv/pool/main/b/base-files-osmc/base-files-osmc_3.1.5_all.deb 404 Not Found [IP: 131.188.12.211 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/m/mariadb-10.3/mariadb-common_10.3.36-0+deb10u1_all.deb 404 Not Found [IP: 151.101.62.132 80]
E: Failed to fetch http://security.debian.org/pool/updates/main/m/mariadb-10.3/libmariadb3_10.3.36-0+deb10u1_armhf.deb 404 Not Found [IP: 151.101.62.132 80]
E: Unable to fetch some archives, maybe run apt-get update or try with --fix-missing?
The unit still plays everything and seems to work. TrackIt doesn’t seem to work anymore, not sure if the update level has anything to do with that though.
Obviously I should have been keep an eye on things and updated on a more regular basis, my fault there.
Anyone have any thoughts as to how to get it to update to the current revision?
Thanks.
