I have an issue with the update process.
Osmc tells me about the update and i accept to install it.
Everything looks fine until it switches to the blue system gui telling me it is checking for packages to install.
This screen gets a timeout after 3 minutes … reboots … and pops a notification about an package installation error and to report it here. So here i am. Fun part of it osmc and kodi both seems to be updatet properly.
Calculating upgrade… The following package was automatically installed and is no longer required:
rbp2-image-4.4.27-7-osmc
Use ‘apt-get autoremove’ to remove it.
Done
osmc@osmc:~$
Well, yeah… I’m certain it will return 0 pending though… MyOSMC may still persist with a notification though. You’ll need to force a manual update from the GUI to clear it.
Yes after first automatic update which has the timeout odmc/kodi is indeed refreshed but the notification sticks.
Having a manual check afterwars results in … no updates found… and notification is gone.
You could disable updates in MyOSMC so that the update prompt never appears in the GUI. It will then just be up to you to use the apt-get commands I posted above to receive updates once a month or so… Remember, alwaysdist-upgrade, never simple upgrade.
There’s nothing for us to fix, if you are referring to OSMC.
We’ve solved this with a friendly warning now
Your system seems OK now, so you should be able to update in future via My OSMC. If you make further changes with APT however, this can’t be guaranteed
