Hi All -
After years of stability, this latest update seems to have broken my system entirely which is unfortunate.
Videos start to play (after short lagged delay) but then “freeze” - not hard freeze, just stop playing - after a few seconds. No audio at all - including GUI effects.
Debug Log
Please post full logs, not just the Kodi log, and turn on Debug.
reproduce the issue
Totally understand. I was a bit lazy about that post. Let’s try this again.
(1) Running RPi model 3B
(2) Have run OSMC for years without issues
(3) Three distinct problems so far but only two show stoppers:
(a) All videos stop playing after a couple seconds (also there is a noticeable lag in starting a video that was not there before the update - ~5 seconds). Video is also very choppy when it starts.
(b) No sound at all - including skin GUI effects
My setup:
RPi connected via HMDI to my receiver (5.1) which is then connected to the tv.
Log:
https://paste.osmc.tv/utojutuqup
Thanks.
First thing to try:
Adjust display refresh rate: Off
Change this to On Start/stop
Also you have
Allow passthrough: false
You probably want that set to True
Give those changes a try and see if that helps.
(1) Changing to display refresh rate: Start/Stop had no effect on video playback.
(2)Passthrough options are not available any longer (I know weird…).
Settings → System → Audio → (go to very bottom) I see “Audio Passthrough” without any options underneath, immediately followed by "Reset above settings to default.
Do you have Menu Level set to expert, did you changed the Audio out device?
Also seems no correct EDID is read did you checked the cables and ensure AVR and TV was on when you booted the Pi?
PCM supported: Max channels: 2, Max samplerate: 32kHz, Max samplesize 16 bits.
Yes to both
I didn’t see anything on there that would cause any major issues given my setup.
Menu level is set to expert. I hadn’t messed with audio out device, willing to give it a shot.
AVR and TV were in the same state as has always worked with the Pi…Pi is on 24/7, TV/AVR are on as needed.
