Hi guys,
I purchased my first Raspberry this week and been actively trying to get it going ever since. As my knowledge is rather limited its been an uphill battle but a fun challenge. Up till now I managed to get my OSMC up and running including Sonarr & Transmission and these downloads get indexed perfectly. The problem I’m running into is that my “old files” are not showing in the library.
I connected my HDD (Seagate Expansion Drive) to the Pi which is mounted on /media/ and I can access videos on it through “Videos” -> “Files” after I loaded them in through Root Files System. However, they refuse to load in the library. I noticed that files I put on my HDD that came with a .nfo or .idx file are getting loaded into the library, though unfortunately this is only a small portion.
Here is my logfile: http://paste.osmc.io/rujuwuquke
As far as I can figure out the problem is that the scraper can’t retrieve the information. I checked the naming guidelines, that’s not it. What could the problem be?
00:05:56 6258.056641 T:1423963120 NOTICE: VideoInfoScanner: Starting scan …
00:05:56 6258.092773 T:1423963120 WARNING: No information found for item ‘/media/Seagate Expansion Drive/TV Shows/Better Call Saul/’, it won’t be added to the library.
00:05:59 6261.643555 T:1423963120 ERROR: Parse: Could not find scraper function GetEpisodeList
00:05:59 6261.643555 T:1423963120 ERROR: Run: Unable to parse web site
00:05:59 6261.644043 T:1423963120 WARNING: No information found for item ‘/media/Seagate Expansion Drive/TV Shows/Suits/’, it won’t be added to the library.
00:05:59 6261.649902 T:1423963120 WARNING: No information found for item ‘/media/Seagate Expansion Drive/TV Shows/The King of Queens/’, it won’t be added to the library.
00:05:59 6261.656250 T:1423963120 WARNING: No information found for item ‘/media/Seagate Expansion Drive/TV Shows/The Office/’, it won’t be added to the library.
00:05:59 6261.674316 T:1423963120 WARNING: No information found for item ‘/media/Seagate Expansion Drive/TV Shows/Workaholics/’, it won’t be added to the library.
00:05:59 6261.708496 T:1423963120 ERROR: Parse: Could not find scraper function GetArt
00:05:59 6261.708496 T:1423963120 ERROR: Run: Unable to parse web site
00:05:59 6261.773438 T:1423963120 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:03
00:06:48 6310.794434 T:1365656560 NOTICE: VideoInfoScanner: Starting scan …
00:06:52 6314.302734 T:1741681648 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
00:06:52 6314.428223 T:1741681648 WARNING: Previous line repeats 1 times.
00:06:52 6314.428223 T:1741681648 NOTICE: LoadJpeg: unable to load http://image.tmdb.org/t/p/original/9NmTVqQ9f2ltecPZgXIj4Bk2c6s.jpg
00:06:54 6316.253418 T:1741681648 WARNING: COMXImageFile::GetCodingType progressive images not supported by decoder
00:06:54 6316.416992 T:1741681648 WARNING: Previous line repeats 1 times.
Greatly appreciate your time!
P.s. As mentioned, I’ve been struggling quite a bit so there might be a couple of other error messages in that log from the last couple of days. Sorry bout that.
