I know that OSMC with Kodi 19 is not supported and that new installations would have to use an image from last 2020.
However, I have an OSMC on a Pi Zero that was having certificate problems with Plex so my first thought was that it could be related to the recent Let’s Encrypt root cert problems so I used command line to update ca-certificates.
It did not resolve the problem so I risked a
sudo apt update
sudo apt full-upgrade
because I saw that mediacenter was not in the list of packages … so I thought it might be safe.
The upgrade ran but failed on reboot with sad face.
So … now I know it was the wrong thing to do … is there a right way?
Meanwhile - I can see from TV screen that OpenBSD ash’s is failing to start and where I am has no USB keyboards so am investigating my mounting SD card on a different RPi via a USB card reader.
I plan to get a cheap USB keyboard tomorrow and will leave it here as a gift!
I don’t have the USB keyboard yet so in-depth investigation is hard (because of sshd failing to start) but I did capture the session output when I ran the upgrade.
In 2 parts because of size limits.
Preconfiguring packages ...
(Reading database ... 32278 files and directories currently installed.)
Preparing to unpack .../base-files_9.9+rpi1+deb9u13_armhf.deb ...
Unpacking base-files (9.9+rpi1+deb9u13) over (9.9+rpi1+deb9u11) ...
Setting up base-files (9.9+rpi1+deb9u13) ...
Installing new version of config file /etc/debian_version ...
Preparing to unpack .../e2fslibs_1.43.4-2+deb9u2_armhf.deb ...
Unpacking e2fslibs:armhf (1.43.4-2+deb9u2) over (1.43.4-2+deb9u1) ...
Setting up e2fslibs:armhf (1.43.4-2+deb9u2) ...
Preparing to unpack .../e2fsprogs_1.43.4-2+deb9u2_armhf.deb ...
Unpacking e2fsprogs (1.43.4-2+deb9u2) over (1.43.4-2+deb9u1) ...
Setting up e2fsprogs (1.43.4-2+deb9u2) ...
update-initramfs: deferring update (trigger activated)
Preparing to unpack .../login_1%3a4.4-4.1+deb9u1_armhf.deb ...
Unpacking login (1:4.4-4.1+deb9u1) over (1:4.4-4.1) ...
Setting up login (1:4.4-4.1+deb9u1) ...
Installing new version of config file /etc/securetty ...
Preparing to unpack .../libperl5.24_5.24.1-3+deb9u7_armhf.deb ...
Unpacking libperl5.24:armhf (5.24.1-3+deb9u7) over (5.24.1-3+deb9u6) ...
Preparing to unpack .../perl_5.24.1-3+deb9u7_armhf.deb ...
Unpacking perl (5.24.1-3+deb9u7) over (5.24.1-3+deb9u6) ...
Preparing to unpack .../perl-base_5.24.1-3+deb9u7_armhf.deb ...
Unpacking perl-base (5.24.1-3+deb9u7) over (5.24.1-3+deb9u6) ...
Setting up perl-base (5.24.1-3+deb9u7) ...
Preparing to unpack .../perl-modules-5.24_5.24.1-3+deb9u7_all.deb ...
Unpacking perl-modules-5.24 (5.24.1-3+deb9u7) over (5.24.1-3+deb9u6) ...
Preparing to unpack .../liblz4-1_0.0~r131-2+deb9u1_armhf.deb ...
Unpacking liblz4-1:armhf (0.0~r131-2+deb9u1) over (0.0~r131-2) ...
Setting up liblz4-1:armhf (0.0~r131-2+deb9u1) ...
Preparing to unpack .../libapt-pkg5.0_1.4.11_armhf.deb ...
Unpacking libapt-pkg5.0:armhf (1.4.11) over (1.4.10) ...
Setting up libapt-pkg5.0:armhf (1.4.11) ...
Preparing to unpack .../libapt-inst2.0_1.4.11_armhf.deb ...
Unpacking libapt-inst2.0:armhf (1.4.11) over (1.4.10) ...
Preparing to unpack .../archives/apt_1.4.11_armhf.deb ...
Unpacking apt (1.4.11) over (1.4.10) ...
Setting up apt (1.4.11) ...
Failed to try-restart apt-daily-upgrade.timer: Unit apt-daily-upgrade.timer is masked.
Failed to try-restart apt-daily.timer: Unit apt-daily.timer is masked.
Preparing to unpack .../apt-utils_1.4.11_armhf.deb ...
Unpacking apt-utils (1.4.11) over (1.4.10) ...
Preparing to unpack .../libsystemd0_232-25+deb9u13_armhf.deb ...
Unpacking libsystemd0:armhf (232-25+deb9u13) over (232-25+deb9u12) ...
Setting up libsystemd0:armhf (232-25+deb9u13) ...
Preparing to unpack .../libnss-myhostname_232-25+deb9u13_armhf.deb ...
Unpacking libnss-myhostname:armhf (232-25+deb9u13) over (232-25+deb9u12) ...
Preparing to unpack .../libpam-systemd_232-25+deb9u13_armhf.deb ...
Unpacking libpam-systemd:armhf (232-25+deb9u13) over (232-25+deb9u12) ...
Preparing to unpack .../systemd_232-25+deb9u13_armhf.deb ...
Unpacking systemd (232-25+deb9u13) over (232-25+deb9u12) ...
Preparing to unpack .../udev_232-25+deb9u13_armhf.deb ...
Unpacking udev (232-25+deb9u13) over (232-25+deb9u12) ...
Preparing to unpack .../libudev1_232-25+deb9u13_armhf.deb ...
Unpacking libudev1:armhf (232-25+deb9u13) over (232-25+deb9u12) ...
Setting up libudev1:armhf (232-25+deb9u13) ...
Preparing to unpack .../libdbus-1-dev_1.10.32-0+deb9u1_armhf.deb ...
Unpacking libdbus-1-dev:armhf (1.10.32-0+deb9u1) over (1.10.28-0+deb9u1) ...
Preparing to unpack .../dbus_1.10.32-0+deb9u1_armhf.deb ...
Unpacking dbus (1.10.32-0+deb9u1) over (1.10.28-0+deb9u1) ...
Preparing to unpack .../libdbus-1-3_1.10.32-0+deb9u1_armhf.deb ...
Unpacking libdbus-1-3:armhf (1.10.32-0+deb9u1) over (1.10.28-0+deb9u1) ...
Setting up systemd (232-25+deb9u13) ...
addgroup: The group `systemd-journal' already exists as a system group. Exiting.
Preparing to unpack .../systemd-sysv_232-25+deb9u13_armhf.deb ...
Unpacking systemd-sysv (232-25+deb9u13) over (232-25+deb9u12) ...
Preparing to unpack .../libgcrypt20_1.7.6-2+deb9u4_armhf.deb ...
Unpacking libgcrypt20:armhf (1.7.6-2+deb9u4) over (1.7.6-2+deb9u3) ...
Setting up libgcrypt20:armhf (1.7.6-2+deb9u4) ...
Preparing to unpack .../libk5crypto3_1.15-1+deb9u3_armhf.deb ...
Unpacking libk5crypto3:armhf (1.15-1+deb9u3) over (1.15-1+deb9u1) ...
Preparing to unpack .../libgssapi-krb5-2_1.15-1+deb9u3_armhf.deb ...
Unpacking libgssapi-krb5-2:armhf (1.15-1+deb9u3) over (1.15-1+deb9u1) ...
Preparing to unpack .../libkrb5-3_1.15-1+deb9u3_armhf.deb ...
Unpacking libkrb5-3:armhf (1.15-1+deb9u3) over (1.15-1+deb9u1) ...
Preparing to unpack .../libkrb5support0_1.15-1+deb9u3_armhf.deb ...
Unpacking libkrb5support0:armhf (1.15-1+deb9u3) over (1.15-1+deb9u1) ...
Preparing to unpack .../libcomerr2_1.43.4-2+deb9u2_armhf.deb ...
Unpacking libcomerr2:armhf (1.43.4-2+deb9u2) over (1.43.4-2+deb9u1) ...
Setting up libcomerr2:armhf (1.43.4-2+deb9u2) ...
Preparing to unpack .../00-libbsd0_0.8.3-1+deb9u1_armhf.deb ...
Unpacking libbsd0:armhf (0.8.3-1+deb9u1) over (0.8.3-1) ...
Preparing to unpack .../01-libhogweed4_3.3-1+deb9u1_armhf.deb ...
Unpacking libhogweed4:armhf (3.3-1+deb9u1) over (3.3-1) ...
Preparing to unpack .../02-libnettle6_3.3-1+deb9u1_armhf.deb ...
Unpacking libnettle6:armhf (3.3-1+deb9u1) over (3.3-1) ...
Preparing to unpack .../03-libp11-kit0_0.23.3-2+deb9u1_armhf.deb ...
Unpacking libp11-kit0:armhf (0.23.3-2+deb9u1) over (0.23.3-2) ...
Preparing to unpack .../04-libgnutls30_3.5.8-5+deb9u6_armhf.deb ...
Unpacking libgnutls30:armhf (3.5.8-5+deb9u6) over (3.5.8-5+deb9u4) ...
Preparing to unpack .../05-libcups2_2.2.1-8+deb9u6_armhf.deb ...
Unpacking libcups2:armhf (2.2.1-8+deb9u6) over (2.2.1-8+deb9u5) ...
Preparing to unpack .../06-libldap-common_2.4.44+dfsg-5+deb9u8_all.deb ...
Unpacking libldap-common (2.4.44+dfsg-5+deb9u8) over (2.4.44+dfsg-5+deb9u4) ...
Preparing to unpack .../07-libldap-2.4-2_2.4.44+dfsg-5+deb9u8_armhf.deb ...
Unpacking libldap-2.4-2:armhf (2.4.44+dfsg-5+deb9u8) over (2.4.44+dfsg-5+deb9u4) ...
Preparing to unpack .../08-libldb1_2%3a1.1.27-1+deb9u2_armhf.deb ...
Unpacking libldb1:armhf (2:1.1.27-1+deb9u2) over (2:1.1.27-1+deb9u1) ...
Preparing to unpack .../09-python2.7_2.7.13-2+deb9u5_armhf.deb ...
Unpacking python2.7 (2.7.13-2+deb9u5) over (2.7.13-2+deb9u3) ...
Preparing to unpack .../10-libpython2.7_2.7.13-2+deb9u5_armhf.deb ...
Unpacking libpython2.7:armhf (2.7.13-2+deb9u5) over (2.7.13-2+deb9u3) ...
Preparing to unpack .../11-libpython2.7-stdlib_2.7.13-2+deb9u5_armhf.deb ...
Unpacking libpython2.7-stdlib:armhf (2.7.13-2+deb9u5) over (2.7.13-2+deb9u3) ...
Preparing to unpack .../12-python2.7-minimal_2.7.13-2+deb9u5_armhf.deb ...
Unpacking python2.7-minimal (2.7.13-2+deb9u5) over (2.7.13-2+deb9u3) ...
Preparing to unpack .../13-libpython2.7-minimal_2.7.13-2+deb9u5_armhf.deb ...
Unpacking libpython2.7-minimal:armhf (2.7.13-2+deb9u5) over (2.7.13-2+deb9u3) ...
Preparing to unpack .../14-libsqlite3-0_3.16.2-5+deb9u3_armhf.deb ...
Unpacking libsqlite3-0:armhf (3.16.2-5+deb9u3) over (3.16.2-5+deb9u1) ...
Setting up libsqlite3-0:armhf (3.16.2-5+deb9u3) ...
(Reading database ... 32279 files and directories currently installed.)
Preparing to unpack .../0-libssl1.1_1.1.0l-1~deb9u4_armhf.deb ...
Unpacking libssl1.1:armhf (1.1.0l-1~deb9u4) over (1.1.0l-1~deb9u1) ...
Preparing to unpack .../1-libwbclient0_2%3a4.5.16+dfsg-1+deb9u4_armhf.deb ...
Unpacking libwbclient0:armhf (2:4.5.16+dfsg-1+deb9u4) over (2:4.5.16+dfsg-1+deb9u2) ...
Preparing to unpack .../2-libsmbclient_2%3a4.5.16+dfsg-1+deb9u4_armhf.deb ...
Unpacking libsmbclient:armhf (2:4.5.16+dfsg-1+deb9u4) over (2:4.5.16+dfsg-1+deb9u2) ...
Preparing to unpack .../3-samba-libs_2%3a4.5.16+dfsg-1+deb9u4_armhf.deb ...
Unpacking samba-libs:armhf (2:4.5.16+dfsg-1+deb9u4) over (2:4.5.16+dfsg-1+deb9u2) ...
Preparing to unpack .../4-python3.5_3.5.3-1+deb9u4_armhf.deb ...
Unpacking python3.5 (3.5.3-1+deb9u4) over (3.5.3-1+deb9u1) ...
Preparing to unpack .../5-libpython3.5-stdlib_3.5.3-1+deb9u4_armhf.deb ...
Unpacking libpython3.5-stdlib:armhf (3.5.3-1+deb9u4) over (3.5.3-1+deb9u1) ...
Preparing to unpack .../6-python3.5-minimal_3.5.3-1+deb9u4_armhf.deb ...
Unpacking python3.5-minimal (3.5.3-1+deb9u4) over (3.5.3-1+deb9u1) ...
Preparing to unpack .../7-libpython3.5-minimal_3.5.3-1+deb9u4_armhf.deb ...
Unpacking libpython3.5-minimal:armhf (3.5.3-1+deb9u4) over (3.5.3-1+deb9u1) ...
Preparing to unpack .../8-samba-common_2%3a4.5.16+dfsg-1+deb9u4_all.deb ...
Unpacking samba-common (2:4.5.16+dfsg-1+deb9u4) over (2:4.5.16+dfsg-1+deb9u2) ...
Preparing to unpack .../9-libss2_1.43.4-2+deb9u2_armhf.deb ...
Unpacking libss2:armhf (1.43.4-2+deb9u2) over (1.43.4-2+deb9u1) ...
Setting up libss2:armhf (1.43.4-2+deb9u2) ...
Preparing to unpack .../passwd_1%3a4.4-4.1+deb9u1_armhf.deb ...
Unpacking passwd (1:4.4-4.1+deb9u1) over (1:4.4-4.1) ...
Setting up passwd (1:4.4-4.1+deb9u1) ...
Preparing to unpack .../00-base-files-osmc_2.9.4_all.deb ...
Unpacking base-files-osmc (2.9.4) over (2.9.2) ...
Preparing to unpack .../01-tzdata_2021a-0+deb9u2_all.deb ...
Unpacking tzdata (2021a-0+deb9u2) over (2019c-0+deb9u1) ...
Preparing to unpack .../02-libssl1.0.2_1.0.2u-1~deb9u6_armhf.deb ...
Unpacking libssl1.0.2:armhf (1.0.2u-1~deb9u6) over (1.0.2u-1~deb9u1) ...
Preparing to unpack .../03-libicu57_57.1-6+deb9u5_armhf.deb ...
Unpacking libicu57:armhf (57.1-6+deb9u5) over (57.1-6+deb9u4) ...
Preparing to unpack .../04-libxml2_2.9.4+dfsg1-2.2+deb9u5_armhf.deb ...
Unpacking libxml2:armhf (2.9.4+dfsg1-2.2+deb9u5) over (2.9.4+dfsg1-2.2+deb9u2) ...
Preparing to unpack .../05-bind9-host_1%3a9.10.3.dfsg.P4-12.3+deb9u8_armhf.deb ...
Unpacking bind9-host (1:9.10.3.dfsg.P4-12.3+deb9u8) over (1:9.10.3.dfsg.P4-12.3+deb9u6) ...
Preparing to unpack .../06-libisc160_1%3a9.10.3.dfsg.P4-12.3+deb9u8_armhf.deb ...
Unpacking libisc160:armhf (1:9.10.3.dfsg.P4-12.3+deb9u8) over (1:9.10.3.dfsg.P4-12.3+deb9u6) ...
Preparing to unpack .../07-libdns162_1%3a9.10.3.dfsg.P4-12.3+deb9u8_armhf.deb ...
Unpacking libdns162:armhf (1:9.10.3.dfsg.P4-12.3+deb9u8) over (1:9.10.3.dfsg.P4-12.3+deb9u6) ...
Preparing to unpack .../08-libisccc140_1%3a9.10.3.dfsg.P4-12.3+deb9u8_armhf.deb ...
Unpacking libisccc140:armhf (1:9.10.3.dfsg.P4-12.3+deb9u8) over (1:9.10.3.dfsg.P4-12.3+deb9u6) ...
Preparing to unpack .../09-libisccfg140_1%3a9.10.3.dfsg.P4-12.3+deb9u8_armhf.deb ...
Unpacking libisccfg140:armhf (1:9.10.3.dfsg.P4-12.3+deb9u8) over (1:9.10.3.dfsg.P4-12.3+deb9u6) ...
Preparing to unpack .../10-libbind9-140_1%3a9.10.3.dfsg.P4-12.3+deb9u8_armhf.deb ...
Unpacking libbind9-140:armhf (1:9.10.3.dfsg.P4-12.3+deb9u8) over (1:9.10.3.dfsg.P4-12.3+deb9u6) ...
Preparing to unpack .../11-liblwres141_1%3a9.10.3.dfsg.P4-12.3+deb9u8_armhf.deb ...
Unpacking liblwres141:armhf (1:9.10.3.dfsg.P4-12.3+deb9u8) over (1:9.10.3.dfsg.P4-12.3+deb9u6) ...
Preparing to unpack .../12-nfs-common_1%3a1.3.4-2.1+deb9u1_armhf.deb ...
Unpacking nfs-common (1:1.3.4-2.1+deb9u1) over (1:1.3.4-2.1) ...
Preparing to unpack .../13-busybox_1%3a1.22.0-19+deb9u2_armhf.deb ...
Unpacking busybox (1:1.22.0-19+deb9u2) over (1:1.22.0-19) ...
Preparing to unpack .../14-libnghttp2-14_1.18.1-1+deb9u2_armhf.deb ...
Unpacking libnghttp2-14:armhf (1.18.1-1+deb9u2) over (1.18.1-1+deb9u1) ...
Preparing to unpack .../15-curl_7.52.1-5+deb9u16_armhf.deb ...
Unpacking curl (7.52.1-5+deb9u16) over (7.52.1-5+deb9u10) ...
Preparing to unpack .../16-libcurl3_7.52.1-5+deb9u16_armhf.deb ...
Unpacking libcurl3:armhf (7.52.1-5+deb9u16) over (7.52.1-5+deb9u10) ...
Preparing to unpack .../17-klibc-utils_2.0.4-9+rpi1+deb9u1_armhf.deb ...
Unpacking klibc-utils (2.0.4-9+rpi1+deb9u1) over (2.0.4-9+rpi1) ...
Preparing to unpack .../18-libklibc_2.0.4-9+rpi1+deb9u1_armhf.deb ...
Unpacking libklibc (2.0.4-9+rpi1+deb9u1) over (2.0.4-9+rpi1) ...
Preparing to unpack .../19-libfreetype6_2.6.3-3.2+deb9u2_armhf.deb ...
Unpacking libfreetype6:armhf (2.6.3-3.2+deb9u2) over (2.6.3-3.2+deb9u1) ...
Preparing to unpack .../20-libjpeg62-turbo_1%3a1.5.1-2+deb9u1_armhf.deb ...
Unpacking libjpeg62-turbo:armhf (1:1.5.1-2+deb9u1) over (1:1.5.1-2) ...
Preparing to unpack .../21-liblua5.3-0_5.3.3-1+deb9u1_armhf.deb ...
Unpacking liblua5.3-0:armhf (5.3.3-1+deb9u1) over (5.3.3-1) ...
Preparing to unpack .../22-libmariadbclient18_10.1.48-0+deb9u1_armhf.deb ...
Unpacking libmariadbclient18:armhf (10.1.48-0+deb9u1) over (10.1.44-0+deb9u1) ...
Preparing to unpack .../23-libnss3_2%3a3.26.2-1.1+deb9u2_armhf.deb ...
Unpacking libnss3:armhf (2:3.26.2-1.1+deb9u2) over (2:3.26.2-1.1+deb9u1) ...
Preparing to unpack .../24-libssh-4_0.7.3-2+deb9u3_armhf.deb ...
Unpacking libssh-4:armhf (0.7.3-2+deb9u3) over (0.7.3-2+deb9u2) ...
Preparing to unpack .../25-libtag1v5-vanilla_1.11.1+dfsg.1-0.3+deb9u1_armhf.deb ...
Unpacking libtag1v5-vanilla:armhf (1.11.1+dfsg.1-0.3+deb9u1) over (1.11.1+dfsg.1-0.1) ...
Preparing to unpack .../26-libtiff5_4.0.8-2+deb9u7_armhf.deb ...
Unpacking libtiff5:armhf (4.0.8-2+deb9u7) over (4.0.8-2+deb9u5) ...
Preparing to unpack .../27-libwebp6_0.5.2-1+deb9u1_armhf.deb ...
Unpacking libwebp6:armhf (0.5.2-1+deb9u1) over (0.5.2-1) ...
Preparing to unpack .../28-libwebpdemux2_0.5.2-1+deb9u1_armhf.deb ...
Unpacking libwebpdemux2:armhf (0.5.2-1+deb9u1) over (0.5.2-1) ...
Preparing to unpack .../29-libwebpmux2_0.5.2-1+deb9u1_armhf.deb ...
Unpacking libwebpmux2:armhf (0.5.2-1+deb9u1) over (0.5.2-1) ...
Preparing to unpack .../30-openssl_1.1.0l-1~deb9u4_armhf.deb ...
Unpacking openssl (1.1.0l-1~deb9u4) over (1.1.0l-1~deb9u1) ...
Preparing to unpack .../31-python-apt-common_1.4.3_all.deb ...
Unpacking python-apt-common (1.4.3) over (1.1.0~beta5) ...
Preparing to unpack .../32-python3-apt_1.4.3_armhf.deb ...
Unpacking python3-apt (1.4.3) over (1.1.0~beta5) ...
Preparing to unpack .../33-python-apt_1.4.3_armhf.deb ...
Unpacking python-apt (1.4.3) over (1.1.0~beta5) ...
Preparing to unpack .../34-python-pil_4.0.0-4+deb9u3_armhf.deb ...
Unpacking python-pil:armhf (4.0.0-4+deb9u3) over (4.0.0-4+deb9u1) ...
Preparing to unpack .../35-python-imaging_4.0.0-4+deb9u3_all.deb ...
Unpacking python-imaging (4.0.0-4+deb9u3) over (4.0.0-4+deb9u1) ...
Preparing to unpack .../36-python-urllib3_1.19.1-1+deb9u1_all.deb ...
Unpacking python-urllib3 (1.19.1-1+deb9u1) over (1.19.1-1) ...
Preparing to unpack .../37-python3-urllib3_1.19.1-1+deb9u1_all.deb ...
Unpacking python3-urllib3 (1.19.1-1+deb9u1) over (1.19.1-1) ...
Preparing to unpack .../38-sudo_1.8.19p1-2.1+deb9u3_armhf.deb ...
Unpacking sudo (1.8.19p1-2.1+deb9u3) over (1.8.19p1-2.1+deb9u2) ...
Preparing to unpack .../39-wpasupplicant_2%3a2.4-1+deb9u9_armhf.deb ...
Unpacking wpasupplicant (2:2.4-1+deb9u9) over (2:2.4-1+deb9u4) ...
Setting up python-apt-common (1.4.3) ...
Setting up perl-modules-5.24 (5.24.1-3+deb9u7) ...
Setting up libapt-inst2.0:armhf (1.4.11) ...
Setting up libperl5.24:armhf (5.24.1-3+deb9u7) ...
Setting up libnettle6:armhf (3.3-1+deb9u1) ...
Setting up python-urllib3 (1.19.1-1+deb9u1) ...
Setting up python3-apt (1.4.3) ...
Setting up libjpeg62-turbo:armhf (1:1.5.1-2+deb9u1) ...
Setting up libnghttp2-14:armhf (1.18.1-1+deb9u2) ...
Processing triggers for mime-support (3.60) ...
Setting up libnss-myhostname:armhf (232-25+deb9u13) ...
Setting up sudo (1.8.19p1-2.1+deb9u3) ...
Setting up busybox (1:1.22.0-19+deb9u2) ...
Setting up libldap-common (2.4.44+dfsg-5+deb9u8) ...
Setting up apt-utils (1.4.11) ...
Setting up tzdata (2021a-0+deb9u2) ...
Current default time zone: 'Europe/Paris'
Local time is now: Fri Oct 29 22:45:34 CEST 2021.
Universal Time is now: Fri Oct 29 20:45:34 UTC 2021.
Run 'dpkg-reconfigure tzdata' if you wish to change it.
Setting up libklibc (2.0.4-9+rpi1+deb9u1) ...
Setting up systemd-sysv (232-25+deb9u13) ...
Setting up samba-common (2:4.5.16+dfsg-1+deb9u4) ...
Setting up libnss3:armhf (2:3.26.2-1.1+deb9u2) ...
Setting up libtiff5:armhf (4.0.8-2+deb9u7) ...
Processing triggers for initramfs-tools (0.130) ...
Setting up libmariadbclient18:armhf (10.1.48-0+deb9u1) ...
Setting up libicu57:armhf (57.1-6+deb9u5) ...
Setting up libbsd0:armhf (0.8.3-1+deb9u1) ...
Setting up libkrb5support0:armhf (1.15-1+deb9u3) ...
Setting up base-files-osmc (2.9.4) ...
Fixing permissions on busybox.
Setting up libxml2:armhf (2.9.4+dfsg1-2.2+deb9u5) ...
Setting up libfreetype6:armhf (2.6.3-3.2+deb9u2) ...
Setting up libhogweed4:armhf (3.3-1+deb9u1) ...
Setting up perl (5.24.1-3+deb9u7) ...
Setting up libssl1.0.2:armhf (1.0.2u-1~deb9u6) ...
Processing triggers for libc-bin (2.24-11+deb9u4) ...
Setting up udev (232-25+deb9u13) ...
addgroup: The group `input' already exists as a system group. Exiting.
Setting up libssl1.1:armhf (1.1.0l-1~deb9u4) ...
Setting up libp11-kit0:armhf (0.23.3-2+deb9u1) ...
Processing triggers for systemd (232-25+deb9u13) ...
Setting up liblwres141:armhf (1:9.10.3.dfsg.P4-12.3+deb9u8) ...
Setting up openssl (1.1.0l-1~deb9u4) ...
Setting up python3-urllib3 (1.19.1-1+deb9u1) ...
Setting up libpython2.7-minimal:armhf (2.7.13-2+deb9u5) ...
Setting up python-apt (1.4.3) ...
Setting up liblua5.3-0:armhf (5.3.3-1+deb9u1) ...
Setting up libpython2.7-stdlib:armhf (2.7.13-2+deb9u5) ...
Setting up libdbus-1-3:armhf (1.10.32-0+deb9u1) ...
Setting up libtag1v5-vanilla:armhf (1.11.1+dfsg.1-0.3+deb9u1) ...
Setting up python2.7-minimal (2.7.13-2+deb9u5) ...
Setting up libpython3.5-minimal:armhf (3.5.3-1+deb9u4) ...
Setting up libwebp6:armhf (0.5.2-1+deb9u1) ...
Setting up libdbus-1-dev:armhf (1.10.32-0+deb9u1) ...
Setting up libwbclient0:armhf (2:4.5.16+dfsg-1+deb9u4) ...
Setting up libk5crypto3:armhf (1.15-1+deb9u3) ...
Setting up klibc-utils (2.0.4-9+rpi1+deb9u1) ...
Setting up libisc160:armhf (1:9.10.3.dfsg.P4-12.3+deb9u8) ...
Setting up libpython3.5-stdlib:armhf (3.5.3-1+deb9u4) ...
Setting up libgnutls30:armhf (3.5.8-5+deb9u6) ...
Setting up wpasupplicant (2:2.4-1+deb9u9) ...
Setting up python2.7 (2.7.13-2+deb9u5) ...
Setting up libwebpmux2:armhf (0.5.2-1+deb9u1) ...
Setting up python3.5-minimal (3.5.3-1+deb9u4) ...
Setting up libisccc140:armhf (1:9.10.3.dfsg.P4-12.3+deb9u8) ...
Setting up libldap-2.4-2:armhf (2.4.44+dfsg-5+deb9u8) ...
Setting up libpython2.7:armhf (2.7.13-2+deb9u5) ...
Setting up libwebpdemux2:armhf (0.5.2-1+deb9u1) ...
Setting up libkrb5-3:armhf (1.15-1+deb9u3) ...
Setting up dbus (1.10.32-0+deb9u1) ...
A reboot is required to replace the running dbus-daemon.
Please reboot the system when convenient.
Setting up python-pil:armhf (4.0.0-4+deb9u3) ...
Setting up python3.5 (3.5.3-1+deb9u4) ...
Setting up libpam-systemd:armhf (232-25+deb9u13) ...
Setting up libldb1:armhf (2:1.1.27-1+deb9u2) ...
Setting up libgssapi-krb5-2:armhf (1.15-1+deb9u3) ...
Setting up python-imaging (4.0.0-4+deb9u3) ...
Setting up libssh-4:armhf (0.7.3-2+deb9u3) ...
Setting up libcups2:armhf (2.2.1-8+deb9u6) ...
Setting up libdns162:armhf (1:9.10.3.dfsg.P4-12.3+deb9u8) ...
Setting up samba-libs:armhf (2:4.5.16+dfsg-1+deb9u4) ...
Setting up libcurl3:armhf (7.52.1-5+deb9u16) ...
Setting up nfs-common (1:1.3.4-2.1+deb9u1) ...
Setting up libisccfg140:armhf (1:9.10.3.dfsg.P4-12.3+deb9u8) ...
Setting up libsmbclient:armhf (2:4.5.16+dfsg-1+deb9u4) ...
Setting up libbind9-140:armhf (1:9.10.3.dfsg.P4-12.3+deb9u8) ...
Setting up bind9-host (1:9.10.3.dfsg.P4-12.3+deb9u8) ...
Setting up curl (7.52.1-5+deb9u16) ...
ash’s not starting because of glibc versions required by underlying security libraries.
They want 2.27 and 2.28 but I think it is 2.24-11 on the system
and mediacenter appears to be failing to start because of issue with
use/lib/kodi/kodi.bin trying to load libbrcmGLESv2.so
Looks like it cannot find it.
As far as I remember … the only unusual thing installed here is OpenVPN (so that I can access my libraries back home via file system).
I’m about to experiment by editing /etc/apt/sources.list and commenting out the osmc repo
and then doing an apt update / --fix-broken install
I can see that this will install libc6 2.28-10+rpi1 along with some other things.
Unfortunately the internet link has dropped to dial up speed so it is taking for ever.
I am now running again.
Commenting out the OSMC repo and using apt to fix things seems to have worked.
I will put the OSMC repo back into the list.
Updates are set to manual (for OSMC but not for Plugins) so hopefully this will be stable for a while until I come back here again next year and can switch it to a more modern RPi.
