Updating system on RPI2 at a certain time
I love the rolling release system but having to update manually is getting tiresome and i would love a way to update my Pi at 4am when i know im never watching. Would that be possible with a cron job?
You can do that, with ‘unattended-upgrades’, but it’s not recommended or supported. The Debian 8.3 update makes this update a take a little while to install, but normally they’re quite fast, and you only get one a month typically.
Hello,
after january update osmc can’t boot…
flash light on RP2
any solution ?
Please start your own thread outlining your symptoms fully and providing full logs. Please see How to submit a useful support request - General - OSMC. Your issue may not necessarily be related to the original poster’s, and to ensure that both they and you are able to get their issue resolved, we would like you to start a new thread for clarity
ok, sorry.
@sean1516 its fairly easy to setup unattended-upgrades for OSMC just google it look at the way they do it then apply it to OSMC
